Hello everyone,
I have a late 2016 15" MBP with Touchbar running macOS High Sierra version 10.13.4. I got it at the beginning of January 2018, so it's about 4 months old.
Yesterday I happened to accidentally spill a glass of orange juice (with bits) on the desk where my Macbook was. At first I thought none of it actually touched my machine, but it seems some of it did. However, it appeared that none of it got into any of the ports (or anywhere else). The Macbook was working perfectly. No problems whatsoever. I had a sturdy case on it anyway, so this must have helped.
About 1-2 hours later after the unfortunate incident, as I was surfing the web (Safari), I noticed the touchbar was completely blank/black, and none of the buttons that usually display on there were visible. I knew everything was just fine the last time I happened to notice it. I tried switching to Photoshop (as this usually brought different touchbar buttons up), but nothing happened. It was dead -- really.
I restarted the machine once -- the problem persisted. Then shut it down and closed the lid, then opened it again -- the machine booted and the touchbar seemed to be working again. Then about 20 minutes later, it disappeared -- once again, completely randomly and unexpectedly. I tried shutting it down again, but this time it didn't work.
After some careful research, I ended up taking several steps to help restore the touchbar to its good working order:
1. Reset NVRAM -- this did absolutely nothing.
2. Reinstalled macOS -- the touchbar worked for some time, then the same thing happened. It just went black.
3. Reset SMC -- same as no. 2 above.
4. Booted in Safe Mode -- same as no. 2 and 3.
5. Run Apple Diagnostics -- no problems found.
However, I noticed another problem alongside the disappearance of the touchbar. Whenever I closed the lid (which supposedly puts the Macbook to sleep) and then opened it again, the Macbook would restart. An error would show up saying that the machine restarted because of a problem. Here's the error report:
FYI, after resetting the SMC and booting in Safe Mode, the touchbar would work until I closed the lid. When I opened it, boom -- it disappeared completely.
Also, there were no settings available for it in the System Preferences, as if my Macbook didn't have a touchbar in the first place!
Oh, and two of the ports seem not to be working properly. The Macbook won't charge when the charger is plugged into any of those two.
Any suggestion? I've kind of exhausted all available options/fixes... It doesn't seem to be a hadware-related problem, though...
Thanks & cheers!
Code:
*** Panic Report ***
panic(cpu 0 caller 0xffffff7f979ef2f1): "Failed to quiesce supporting devices\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleACPIPlatform/AppleACPIPlatform-281.50.17/AppleACPIPlatformPower.cpp:1970
Backtrace (CPU 0), Frame : Return Address
0xffffff922f69b9b0 : 0xffffff8014e6e166
0xffffff922f69ba00 : 0xffffff8014f96714
0xffffff922f69ba40 : 0xffffff8014f88a00
0xffffff922f69bac0 : 0xffffff8014e20180
0xffffff922f69bae0 : 0xffffff8014e6dbdc
0xffffff922f69bc10 : 0xffffff8014e6d99c
0xffffff922f69bc70 : 0xffffff7f979ef2f1
0xffffff922f69bcd0 : 0xffffff7f979eeec2
0xffffff922f69bd20 : 0xffffff7f979f340f
0xffffff922f69bd40 : 0xffffff80154b9ef8
0xffffff922f69bd90 : 0xffffff80154e8293
0xffffff922f69be00 : 0xffffff8015481ddb
0xffffff922f69be50 : 0xffffff801547efc8
0xffffff922f69beb0 : 0xffffff801547bfa3
0xffffff922f69bef0 : 0xffffff801547be32
0xffffff922f69bf30 : 0xffffff8015498772
0xffffff922f69bf70 : 0xffffff8015497dac
0xffffff922f69bfa0 : 0xffffff8014e1f4f7
Kernel Extensions in backtrace:
com.apple.driver.AppleACPIPlatform(6.1)[FC118BB9-2E67-35DD-BB25-BA6DFAF5AE88]@0xffffff7f979e3000->0xffffff7f97a7efff
dependency: com.apple.iokit.IOACPIFamily(1.4)[95DA39BB-7C39-3742-A2E5-86C555E21D67]@0xffffff7f95c0d000
dependency: com.apple.iokit.IOPCIFamily(2.9)[1850E7DA-E707-3027-A3AA-637C80B57219]@0xffffff7f95694000
dependency: com.apple.driver.AppleSMC(3.1.9)[497D69E7-C1FB-3435-B4D9-ED1DC51727D1]@0xffffff7f95c16000
BSD process name corresponding to current thread: kernel_task
Mac OS version:
17E199
Kernel version:
Darwin Kernel Version 17.5.0: Mon Mar 5 22:24:32 PST 2018; root:xnu-4570.51.1~1/RELEASE_X86_64
Kernel UUID: 1B55340B-0B14-3026-8A47-1E139DB63DA3
Kernel slide: 0x0000000014c00000
Kernel text base: 0xffffff8014e00000
__HIB text base: 0xffffff8014d00000
System model name: MacBookPro13,3 (Mac-A5C67F76ED83108C)
System uptime in nanoseconds: 1876905299459
last loaded kext at 246169910116: com.apple.filesystems.msdosfs 1.10 (addr 0xffffff7f99412000, size 69632)
last unloaded kext at 423358886840: com.apple.filesystems.msdosfs 1.10 (addr 0xffffff7f99412000, size 61440)
loaded kexts:
com.paragon-software.filesystems.ntfs 23.0.15
com.apple.filesystems.smbfs 3.2.2
com.apple.driver.AudioAUUC 1.70
com.apple.driver.ApplePlatformEnabler 2.7.0d0
com.apple.driver.AGPM 110.23.33
com.apple.driver.X86PlatformShim 1.0.0
com.apple.filesystems.autofs 3.0
com.apple.driver.AppleUpstreamUserClient 3.6.5
com.apple.kext.AMDFramebuffer 1.6.6
com.apple.kext.AMDRadeonX4000 1.6.6
com.apple.driver.AppleHDA 281.51
com.apple.driver.AppleGraphicsDevicePolicy 3.18.48
com.apple.AGDCPluginDisplayMetrics 3.18.48
com.apple.driver.AppleHIDALSService 1
com.apple.driver.AppleHV 1
com.apple.iokit.IOUserEthernet 1.0.1
com.apple.driver.AGDCBacklightControl 3.18.48
com.apple.iokit.IOBluetoothSerialManager 6.0.5f3
com.apple.driver.pmtelemetry 1
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.AppleIntelSKLGraphics 10.3.2
com.apple.driver.AppleIntelPCHPMC 2.0.1
com.apple.kext.AMD9500Controller 1.6.6
com.apple.driver.eficheck 1
com.apple.driver.AppleIntelSlowAdaptiveClocking 4.0.0
com.apple.driver.SMCMotionSensor 3.0.4d1
com.apple.driver.AppleMuxControl 3.18.48
com.apple.driver.AppleIntelSKLGraphicsFramebuffer 10.3.2
com.apple.driver.AppleMCCSControl 1.5.4
com.apple.driver.AppleOSXWatchdog 1
com.apple.driver.AppleEmbeddedOSSupportHost 1
com.apple.driver.AppleThunderboltIP 3.1.1
com.apple.filesystems.hfs.kext 407.50.6
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.BootCache 40
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0
com.apple.driver.AppleTopCaseHIDEventDriver 133
com.apple.filesystems.apfs 748.51.0
com.apple.driver.AirPort.BrcmNIC 1240.29.1a7
com.apple.driver.AppleSmartBatteryManager 161.0.0
com.apple.driver.AppleACPIButtons 6.1
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleSMBIOS 2.1
com.apple.driver.AppleACPIEC 6.1
com.apple.driver.AppleAPIC 1.7
com.apple.nke.applicationfirewall 183
com.apple.security.TMSafetyNet 8
com.apple.security.quarantine 3
com.apple.kext.triggers 1.0
com.apple.kext.AMDRadeonX4100HWLibs 1.0
com.apple.kext.AMDRadeonX4000HWServices 1.6.6
com.apple.driver.DspFuncLib 281.51
com.apple.kext.OSvKernDSPLib 526
com.apple.iokit.IOAVBFamily 675.6
com.apple.plugin.IOgPTPPlugin 675.12
com.apple.iokit.IOEthernetAVBController 1.1.0
com.apple.driver.AppleSSE 1.0
com.apple.iokit.IOBluetoothHostControllerUARTTransport 6.0.5f3
com.apple.iokit.IOBluetoothHostControllerTransport 6.0.5f3
com.apple.driver.AppleBacklightExpert 1.1.0
com.apple.AppleGPUWrangler 3.18.48
com.apple.iokit.IONDRVSupport 519.15
com.apple.driver.usb.IOUSBHostHIDDevice 1.2
com.apple.driver.AppleHDAController 281.51
com.apple.iokit.IOHDAFamily 281.51
com.apple.iokit.IOAudioFamily 206.5
com.apple.vecLib.kext 1.2.0
com.apple.iokit.IOSlowAdaptiveClockingFamily 1.0.0
com.apple.driver.AppleGraphicsControl 3.18.48
com.apple.iokit.IOAcceleratorFamily2 378.18.1
com.apple.iokit.IOSurface 211.12
com.apple.driver.AppleSMBusController 1.0.18d1
com.apple.driver.AppleIntelLpssUARTv1 3.0.60
com.apple.driver.AppleIntelLpssUARTCommon 3.0.60
com.apple.driver.AppleOnboardSerial 1.0
com.apple.iokit.IOSkywalkFamily 1
com.apple.iokit.IOSerialFamily 11
com.apple.kext.AMDSupport 1.6.6
com.apple.AppleGraphicsDeviceControl 3.18.48
com.apple.iokit.IOGraphicsFamily 519.15
com.apple.driver.X86PlatformPlugin 1.0.0
com.apple.driver.IOPlatformPluginFamily 6.0.0d8
com.apple.driver.usb.cdc.ncm 5.0.0
com.apple.driver.usb.AppleUSBiBridge 1.0
com.apple.driver.usb.cdc 5.0.0
com.apple.driver.usb.networking 5.0.0
com.apple.driver.usb.AppleUSBHostCompositeDevice 1.2
com.apple.driver.AppleUSBHostMergeProperties 1.2
com.apple.filesystems.hfs.encodings.kext 1
com.apple.driver.AppleActuatorDriver 1404.4
com.apple.driver.AppleHIDKeyboard 205
com.apple.driver.AppleHSBluetoothDriver 133
com.apple.driver.IOBluetoothHIDDriver 6.0.5f3
com.apple.iokit.IOBluetoothFamily 6.0.5f3
com.apple.driver.AppleMultitouchDriver 1404.4
com.apple.driver.AppleInputDeviceSupport 1404.3
com.apple.driver.AppleHSSPIHIDDriver 53
com.apple.driver.AppleThunderboltDPInAdapter 5.5.3
com.apple.driver.AppleThunderboltDPAdapterFamily 5.5.3
com.apple.driver.AppleThunderboltPCIDownAdapter 2.1.3
com.apple.driver.AppleHSSPISupport 53
com.apple.iokit.IONVMeFamily 2.1.0
com.apple.driver.AppleIntelLpssSpiController 3.0.60
com.apple.iokit.IO80211Family 1200.12.2
com.apple.driver.mDNSOffloadUserClient 1.0.1b8
com.apple.driver.corecapture 1.0.4
com.apple.driver.AppleThunderboltNHI 4.7.2
com.apple.driver.AppleHPM 3.1.3
com.apple.iokit.IOThunderboltFamily 6.7.8
com.apple.driver.AppleIntelLpssI2CController 3.0.60
com.apple.driver.AppleIntelLpssDmac 3.0.60
com.apple.driver.AppleIntelLpssGspi 3.0.60
com.apple.driver.AppleIntelLpssI2C 3.0.60
com.apple.driver.usb.AppleUSBXHCIPCI 1.2
com.apple.driver.usb.AppleUSBXHCI 1.2
com.apple.driver.usb.AppleUSBHostPacketFilter 1.0
com.apple.iokit.IOUSBFamily 900.4.1
com.apple.driver.AppleEFINVRAM 2.1
com.apple.driver.AppleEFIRuntime 2.1
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.iokit.IOSMBusFamily 1.1
com.apple.security.sandbox 300.0
com.apple.kext.AppleMatch 1.0.0d1
com.apple.driver.DiskImages 480.50.10
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleEffaceableStorage 1.0
com.apple.driver.AppleKeyStore 2
com.apple.driver.AppleUSBTDM 439.50.6
com.apple.driver.AppleMobileFileIntegrity 1.0.5
com.apple.iokit.IOUSBMassStorageDriver 140.50.3
com.apple.iokit.IOSCSIBlockCommandsDevice 404.30.2
com.apple.iokit.IOSCSIArchitectureModelFamily 404.30.2
com.apple.iokit.IOStorageFamily 2.1
com.apple.driver.AppleCredentialManager 1.0
com.apple.driver.KernelRelayHost 1
com.apple.iokit.IOUSBHostFamily 1.2
com.apple.driver.usb.AppleUSBCommon 1.0
com.apple.driver.AppleBusPowerController 1.0
com.apple.driver.AppleSEPManager 1.0.1
com.apple.driver.IOSlaveProcessor 1
com.apple.iokit.IOReportFamily 31
com.apple.iokit.IOTimeSyncFamily 675.12
com.apple.iokit.IONetworkingFamily 3.4
com.apple.driver.AppleACPIPlatform 6.1
com.apple.driver.AppleSMC 3.1.9
com.apple.iokit.IOPCIFamily 2.9
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.pthread 1
com.apple.kec.Libm 1
com.apple.kec.corecrypto 1.0
EOF
Model: MacBookPro13,3, BootROM MBP133.0242.B00, 4 processors, Intel Core i7, 2.7 GHz, 16 GB, SMC 2.38f7
Graphics: Intel HD Graphics 530, Intel HD Graphics 530, Built-In
Graphics: Radeon Pro 455, AMD Radeon Pro 455, PCIe
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.77.37.29.1a7)
Bluetooth: Version 6.0.5f3, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: iBridge
Thunderbolt Bus: MacBook Pro, Apple Inc., 33.1
Thanks & cheers!
