MacRumors
macrumors bot
70,430
42,090
Following a flood of reports and complaints, Spotify has acknowledged that its app may be causing excessive battery drain and overheating issues on iOS 14.8 and the latest iOS 15 update, promising a fix in the not-so-distant future.
In a long and ongoing support thread on its website, which started weeks ago, Spotify says it is aware of battery drain reports and that it has passed those reports onto its technical iOS team. Spotify doesn't state when a fix could be coming or whether it would be an app update or other troubleshooting steps.
Users reporting the issue on the thread state that Spotify is listed as a consumer of battery life due to background activity, with no clear reason why. While most of the reports are from users running iOS 14.8 and iOS 15.0, there are also other sporadic reports of battery drainage on older iOS versions. Those users are advised to update for a possible patch and improved security.
While Spotify is being held as the main culprit for the excessive drainage, it could also be a bug in iOS 15 for some users. iOS 15 has been littered with multiple bugs, including one limiting Apple Watch functionality with the just-released iPhone 13, issues with Apple Music, and other bugs that Apple has promised fixes for. Apple may be planning to release iOS 15.0.1 as soon as this week to patch those issues and others.
Article Link: Spotify Acknowledges Battery Drain Issues on iOS 14.8 and iOS 15, Promises Fix Soon
I gotta say, all things considered Spotify is a better app than Apple Music. And this is coming from someone with 4 HomePods / minis.
I was hoping for some big AM upgrades (better recommendations, faster and more responsive app, etc.) at the September event.
My wife has been complaining her 12 Pro is dying before the afternoon, looked at her battery thing and it showed Spotify was draining pretty much all of it with Facebook a distant second. That's pretty bad when you drain more battery than Facebook
In an ironic twist, the only app that drains more battery than Facebook is Instagram.
This reminds me of when Facebook got cought playing silent music, to be able to be always running on after the user left the app. You had to force shut it by pushing it up to stop it from running, and of course draining the battery. The silent music was done, because Apple allowed apps playing music to stay on in the background, of-course because users usually want their music to continue playing, but FB decided to play silent music and then could stay on up/downloading in the background what the user was doing.
Spotify owes us an explanation why it was doing so much work in the background.
EDIT: As, commenters have been accusing me of making this up, here is a link for those that can't or won't google it. As an iOS programmer, their explanation did not make sense of forgetting playing silent sound on. https://techcrunch.com/2015/10/22/f...kcPXnorOuftOBbtJ2yQF0nVW87lZIECYDXhM8GOwgdC82
They work really closely with Facebook. They support FB ads and friends natively.
Reactions: haruhiko
I've noticed a battery drain issue on my iPhone 12 since upgrading to iOS 15. My assumption is that it is due to the Live Text feature, where the iPhone scans all my photos to know the text. It started to show on my spotlight search results. After a week, I feel it's more or less back to normal.
Any source for that claim? I've never heard it.
  • Wow
Reactions: Morgenland
That sounds pretty made up. Any proof or references to it?
Didn't think so.
The suggestion is to update for a possible patch?. What kind of suggestion is that?.
“We suggest you charge more often your device”.
Apps consume battery, the App Store review process doesn’t include performance testing. If you’d like for App updates to take significantly longer you could try and convince Apple to do so but this is on Spotify not Apple.
Could be either. If it's only on specific versions of iOS, Apple may have some kind of bug that's preventing Spotify from being able to properly sleep...
Although I suppose if that were the case, it should impact other apps. Somebody mentioned Spotify uses Electron - what other major apps use that framework? Does Microsoft's apps? Do they have similar problems?
