xpaulinax
33
So basically I live in an apartment which already has WiFi.
I've encountered this problem on a few occasions and can usually troubleshoot, but not today!
The problem is sometimes when I try to connect to WiFi I get an error message which says "can't connect to WiFi because another device on this network is using your computers IP address. Try again later or change your IP address"....something like that.
So what I do is I go to network preferences>advanced>TCP/IP> using DHCP w manual address
So i change the address but then it won't connect to router so then I'll change back to using DHCP and renew lease.
But this isn't working anymore. I've tried every combination of things and have restarted multiple times but still can't connect to internet BC some ******* has my IP address. So how can I fix this?
Please help. Idk what to do and I have no internet and am using my phone.
Thanks
Do you have access to the router? Sounds like it's not assigning u an ip, which means the dhcp is off. Access the router n turn it on?
Idk how to work the router. First of all I can't reach it BC its on the ceiling of my bedroom closet. And idk if I can actually turn it off or if my apartment people have to do it.
That's pretty much the problem though BC if I set it to "using DHCP" and then hit apply it tells me I have no IP address
If it belongs to your apartment's people, then talk to them. They may have assigned your ip to someone else by accident. They shld be able to assign you a new one and solve this once n for all.
I wonder if there's anything else I can do besides turning off the router to fix it though
Is there a way to request a new DHCP address from my computer? I feel like I shouldn't be having this problem
More importantly, how can I not have this problem again?
How can I automatically be assigned an IP address and not have to worry about it?
The problem likely occurs because you left with your MBP and your lease expired. Someone else then was assigned it. When you returned your MBP attempted to use the last address assigned and got the conflict. Usually, renewing your dhcp address will fix the error.
Getting a fixed or reserved address requires the router admin to set it up.
Renewing dhcp does not work.
When I do that it says "no IP address assigned"
I just came over to a friends place and I'm still having the same problem
So its something w my computer
I changed my IP address and it says I'm connected but I get the ! At the top that shows WiFi signal. Says no internet connection. But when I change from manual address to using dhcp it says no IP address assigned
Actually a correction, when I hit "using DHCP" it will assign me an address but I still have no internet connection so it doesn't really work
Well it says I'm connected but no webpages will load
Clear out all the settings. You seem to have manual configuration on, and the only thing affecting you now should be a misconfigured DNS setting.
well, i think i fixed it.
in network preferences, at the top pull down menu i went to edit locations, and made a new location. then i renewed the DHCP lease and now i have internet access. yay.
thanks for the responses:)
I know this post is old but I am going to post the fix for anyone who comes across this while looking for a fix to this wi if connectivity problem.
Youtube can explain it better; but I will post anyway.
1. While phone is on heat it up with a blow dryer until the screen says TEMPERATURE then turn it off and let it cool down then turn it on. THIS IS A SURE FIX for wi if connectivity issues -
1. Greyed out out wi if selection .
2. No network displayed
3. Intermittent wi if loss.
look it up on youtube " how to fix iphone wi fi .
Logic board hardware issue that apple knows about but won't reveal it.:confused:
