Hey guys, I have been a mac person for several years and have found all hardware and software to work perfectly. That is until now...
I am trying to sync my two itunes libraries using Tune Ranger and Supersync (I have tried them both - though obviously not at the same time). The computers talk to each other no problem. I can see the itunes libraries no problem. I get the compare screen and can see all the discrepanices no problem. Then - in Supersync - I click synchronize and everything seems to work perfectly. Files are transferring and everything looks good. About 25-30 minutes later (it takes a while to transfer the files) I get errors saying "host is down" or "operation timed out."
This obviously means there is a communication issue over the network or on the computers. I initially thought one of them might be going to sleep and that was causing the problem. However, I verified that I have them both set to NOT go to sleep. I still have the same issue. Could this be a router or a cable modem issue?
All computers are running the very latest OS with updates. Thanks in advance for any help.
