So there...
Ps. I also have another dlink router, and an antique Farallon Starlet/4 hub/switch to throw in the mix, if only I knew where. Thanks all!!!!
you could maybe try a few things..
3.You could just use a 4 port hub/switch instead of the netgear, it would simplify the network and should work...
Russ.
Thats an interesting solution you've come up with. I'm glad you got things going! Now what do you mean by everyone using the network? The internet, or internal file sharing, etc? Maybe hardwiring the farrallon to the A.express would solve things.
The d-link acting as a hub may be pretty slow when a lot of file sharing is going on too, specifically between more than 2 computers at a time. a switch would do it better. If its internet use, it may be because the wireless dongle cant handle all that traffic.
Anyway, describe your usage when you feel the limitation.
(I may be out of solutions from here on though.. I'm not quiet a network engineer.. just the family and friends dude)
And what do you use for sketching?![]()
