Zysq
9
I bought a MBP 15' a few days ago and was getting to know it( it is my first mac). I wanted to change the System folder to be unreadable for users and after doing that my Macbook stopped working so I restarted it and it loads up to a blue screen and seems to be loading forever. What should I do?
Please help me with that issue.
Thanks in advance.
Is there no other solution? I have so much valuable data on it that this would be painful.
EDIT: Is it possible to reinstall the system without losing the data on HDD?
@mulo
If you dont want to help, don't do it. I said I need that help urgently as I'm leaving abroad tommorow and need to have the laptop working.
And I didn't get your "default behaviour"
@topic
Someone kind enough to explain me how to deal with this problem?
@mulo
@topic
I think you need to boot to single user mode and rename. Did you rename the System folder?
@alexprice
How can I boot into single user mode?
Sorry but i'm completely new to the Mac world.:)
@alexprice
Hi,
Restart the Mac, when the screen goes black, hold down CMD and S
Let go of the keys when you see a black screen with white writing.
Then at the command prompt type:
/sbin/mount -uw /
Then type:
cd /
Then:
mv systemfoldername System
(Replace systemfoldername with actual name of current system folder)
Then restart by typing:
reboot
I hope this helps :)
All right I used the disc utility on the Mac OS X install CD and that helped.
THanks for help though, really.
Yeah, it's all fine. I'm writing from my Macbook now :D
And thanks again !
I think what most people meant were in good faith; it is easy to come off as sarcastic on forums when it is not meant in that way. When he recommended doing the reinstall, what he meant was in your situation, that is the typical solution (the default behavior=techy term). If you are not familiar with OS X, going through a gazillion steps is more than likely going to be frustrating. Also, since you are leaving to travel and the current config shows that there is an issue, wiping everything and reinstalling the OS gives you the best chance of taking care of everything.
I would still reinstall. And above all, be sure to back-up all important data. Apple's OS X allows you to use a feature called the 'Time Machine' in which you can make backups allowing you to literally skip back to how the machine was at a previous date. Another feature, Carbon Cloner, allows you to make an exact copy of your hard drive. Now, you do need an external hard drive for this, as putting backup data on the same drive makes no sense
