MCube74
macrumors 65816
I have a couple of back skins left for my iPhone 12 Pro Max.
Wondering if they can be installed on the iPhone 13 Pro max?
don't think so, was thinking the same as I have some clear matt 12 pro skins, but my 13 pro case came today and the camera cut out is larger. Rather than spend on a new skin, I was just going to take a pair of scissors or stanley knife to it and trim the cutout to fit. The buttons look to be slightly different heights too to will probably trim the strips that go on the side too.
I feel the back skin for the iPhone 12 Pro Max should fit the iPhone 13 Pro Max
I feel it is only the skin for 12 pro will not fit the 13 Pro.
However for the 13 pro max you will have to buy the skins again because the mute switch is slightly moved.
I have sent dBrand an email but not yet received a reply.
The camera bump is larger on the 13 pro and pro max so skins for the 12 pro and pro max will not fit without modification.
But the camera count out (the big square) of the 12 pro max is the same as the 13 pro max. The camera bump doesn’t have to be fully covered.
What modifications are you suggesting needs to be done?
No.
