Windows 7 bootcamp - How do I enable 2 finger tap for right click? Tap to left click?
Discussion in 'MacBook Pro' started by acribb, May 2, 2010.
  1. acribb macrumors regular
    Nov 30, 2007
    #1
    How do I enable a single tap to left click and a 2 finger tap for right click in Windows 7 bootcamp? I have already installed all the bootcamp drivers and I can use 2 finger scroll on the trackpad. I would just rather tap rather than have to click the button.
    I can't find any trackpad configuration in Windows 7.
    Thanks for any insight.
    This is on a new 15" i7.
  2. Matthew Yohe macrumors 68020
    Oct 12, 2006
    #2
    Why are you running bootcamp?
    If it's any other reason than games, then you just need to install VirtualBox (free!) and run Windows 7 inside of OS X. You'll get all of the hardware/driver support that you want, and you don't have to reboot.
  3. acribb thread starter macrumors regular
    Nov 30, 2007
    #4
    I'm running Parallels with bootcamp. I boot to Windows 7 with bootcamp when I want to play games.
  4. jmdMac macrumors regular
    Feb 8, 2010
    Alaska
    #5
    How is that set up working for you? I have the same one in mind, as soon as my windows 7 and parallels arrive in the mail...
  5. sheiklynx macrumors newbie
    Nov 4, 2013
    #6
    Install trackpad drivers
    If using bootcamp 5, download the drivers for bootcamp using an USB with FAT32 formating.
    Open the USB in windows. Navigate to USB > BootCamp > Drivers > Apple, dobleclick on AppleMultiTouchTrackPadInstaller64.exe . This will install the drivers for the trackpad and enble the tab Trackpad in Control Panel > BootCamp . In this tab you can enable secondary click with two fingers.
Share This Page
