culturekiller
14
i have a winterboard theme called "typophone" that changes what i see on the lockscreen.
doesnt affect the springboard.
i have a springboard wallpaper and a lockscreen wallpaper.
however, when people call the background is pure black wallpaper. it may have been the original pure black background that came with the typophone winterboard theme.
how do i have my calling wallpaper same as the one on my lockscreen? i tried navigating the winterboard setting page, but im confused.
these are my lockscreen and homescreen.
when the people call, i see black background. how do i have the lockscreen image when peope call?
Hmmm..Try replacing the LockBackground.png in the Typophone folder? Just a thought, I'm using the same LS but haven't run into that issue.
sorry how would i go about doing this?
do i go to cydia > packages > something? im clueless as how to find the process for even locating folders or whatever =(
wow thanks. it worked. i went into the theme and deleted the black background image, and now when someone calls it uses that rainbow image for my lockscreen that i have in my camera roll.
i still feel like this isnt the best way to do it..lol..but thanks again.
does this mean i can modify anything from the typophone theme?
like i can modify the words at the bottom "slide to unlock" through the SSH thing? not sure where i could locate that file. thanks again
As far as fixing your problem, yes it is the best way. As far as SSHing, yes it is the best way [or you could use iFile, I prefer to do things on my computer]
You can modify the theme, but its not so easy and straightforward. Look through the folders of the theme and you'll find everything.
