Why have 2 rarely used Thunderbolt ports on your entry level laptop?
It's probably not going to be an entry level laptop, but more of a rMBP with smaller screen. One port is at least likely to be used for a screen since it doubles as a display port.
There are several other Mac-based options for "3D gamers". Why should this particular model be saddled with a heat-generating, battery-draining chipset that is unnecessary for the majority of users?
I know the cables are available, but that doesn't stop the ruling of their being illegal ...
Actually, I suspect that Apple has some sort of deal going with Intel that rewards Apple in some way for trying to push TB as a new standard. You know, special pricing or early access to a new chip during production ramp-up, something along those lines. Works for Intel, because if TB is eventually widely adopted, then it gives manufacturers one more reason to go with Intel. Works for Apple, because it can claim that it has this new, advanced port tech. The problem is that Apple has implemented its port adoption strategy poorly. If Apple had itself had produced a wide array of affordable hubs and devices to use the port, then it could have taken off. Because Apple is taking a hands-off approach with peripherals, adoption is glacial due to a lack of built-in processor support, likely expensive licensing, and a limited market.I was trying to be fair and objective.Obviously the average consumer and especially those targeted by the 13" aren't Thunderbolt users. IMHO, it is mindless to put two of these ports on these computers. If and when the tech becomes widespread, these current machines will be obsolete. USB 3 is far more useful and practical for the vast majority and will be for at least a few years. And I'm being generous again.
As for the other reply to mine about HDMI - I know the cables are available, but that doesn't stop the ruling of their being illegal ... one kind of came before the other there.
I was really holding off on getting a new laptop hoping the new 13" would have dedicated GPU (still possible) and would be massively disappointed if they choose to skimp on this. Regardless of what others may be saying about the hd4000 being fully capable of handling those pixels on paper and using synthetic benchmarks the fact is on OSX we are getting lag when using a much more powerful GPU which will be so much worse with an integrated GPU.
Unless apple has resolved any driver / software related issues causing the lag, we WILL be getting a much worse experience regardless of what the hd4000 is capable of on paper. On top of that, there is no way I am spending $1,500+ on any laptop without a dGPU since I am a pro user using serious apps alongside some modern games and prefer the portability of a 13" when meeting clients or traveling. No GPU = not a real pro device, might as well get an air.
Anandtech and Tom's Hardware have taken a look at those +$200 Thunderbolt sporting boards and in some external enclosures. It is fast and with the one cable to "rule" them all nonsense but it still spinning around the vaprorware drain.I see that Asus and MSI now have motherboards with Thunderbolt. I guess it's a start but it's going to be years before it is popular for the masses, if ever.
Dropping Thunderbolt onto an already expensive ATX board adds about another $60. Half of that being for the controller itself. On the other hand you also have Mini-ITX boards showing up with Thunderbolt support.People buying ATX motherboards are already niche, I bet those buying boards more expensive than 100$ is a much smaller niche within a niche. Now for those 200$ guys...
Unit count must be ridiculously low on those.![]()
3D gamers can also run the display in non-Retina mode. I don't get why that's even a complaint...
Link to such a ruling ? The people running the HDMI standard have no force of law. Adapters are not illegal. They might not be sanctionned by a standard body, but they are not illegal.
DisplayPort is a VESA standard while HDMI is managed by the HDMI Forum, an industry association.
EDIT : http://www.vesa.org/displayport-developer/about-displayport/
VESA even markets DP as fully HDMI compatible as far as transport of Video/Audio. Devices that support DP++ are dual-mode and will sense if a display is connected through HDMI, switching the signal to straight HDMI, requiring thus only a completely passive, pin-to-pin adapter. This is all baked into the DisplayPort standard. Of course, you don't get the added features of HDMI such as CEC (a remote controlling standard so that a single device can control all its connected devices through its own interface) with this method, only Video/Audio transport.
So in essence, you're not just wrong, you're completely off base with your comments.
http://www.slashgear.com/hdmi-to-mini-displayport-cables-declared-illegal-08164010/
It wasn't posted on April 1st either. Beyond that, I had no reason to doubt it, PLUS it does seem typical of the industry.
I am still "right", for the zero difference it makes, that minidisplayport is far less convenient than hdmi in my life, which was let's face it my main point; there was never an argument here.
I just hope the bezel of this 13" retina MBP is smaller than the current 13" MBP.
I think a number of people have a problem with these persistent leaks with actual photos of parts. That is a serious problem and if the manufacturer was located in the US, somebody would be investigated for insider trading or misappropriation. Because the manufacturer is located in China, the SEC cannot prosecute or investigate the leakers. If, however, someone at Apple were to leak insider information about future products, they could be charged under SEC regulations and fined or imprisoned.
I don't think nobody wants to see people go to jail.
I miss this site when we had unsubstantiated rumors and speculation with very few actual leaked parts to go on. All of these leaks take some of the fun out of the keynotes.
You seem to be under the mistaken impression that insider trading requires the person with the information on the inside to make the trade. An insider can leak information to a friend and if that friend makes buys or sells based on that information, both people can be charged with insider trading.@ Aristotle
I don't have aproblem with leaks... Define "most!". did you take a survey?
who knows if Apple has any role in some "leaks."
SEC has no jurisdiction over leaked parts. The SEC only can prosecute if somone trades the stock on inside info that has not been disclosed to the public. These are people making public rumors. This has nothing to do with insider trading. Posts like yours, with.false statements, are exasperating!!!! and take all the fun out of Mac Rumors.
Excuse me.... The SEC has failed in many ways to prosecute insider trading as well as other illegal trading activities. And the US congress members -- our elected officials -- have benefited for years trading on insider info.
Keynote speeches are mostly boring.... Particularly with SJ gone....
Heh, and it is very Apple-like to leave a couple of years ago in the dust. In my life, HDMI is far more relevant now than it was a couple of years ago; I have a TV with it and have also bought one for my mother and one for my father, and a Dell with it ... with no connection issues; it is only the minidisplayport that causes issues, and I would rather not have to bother with another cable or adapter - that is just too Apple-like for me now.
As for the other reply to mine about HDMI - I know the cables are available, but that doesn't stop the ruling of their being illegal ... one kind of came before the other there. In any case my main reaction was to find it amusing - this port business be insane.
Will it be allowed on planes?
If you could choose one, what would you have: discrete graphics or quad core processing?
