Had my phone for 1.5 months now if I remember correctly and it was 100% capacity and checked today and was 99%. It wont make much difference but already moving down. Anyone else??
Yeah and it is not a big deal with the max or really any phone now. Just was wondering if anyone else saw the same drop.If it goes 80% or under during warranty period Apple will replace it. Other than that, nothing you can do unless you want to start minimizing battery usage and change your charging habits
I've had my 13 Pro since release day, so almost 3 months. Have run the battery below 10% multiple times, charge it to 100% overnight on a MagSafe charger every single night. Battery capacity is still at 100%.Do you wirelessly charge or use the MagSafe charger? That’s probably why.
Lol, my 12 Pro Max is exactly 364 days old today, and its at 80% battery health with 345 cycles, and Apple says its 'in good condition'. They won't replace it unless its at 79%.
They used cheap quality batteries in the 12 series, people just upgraded rather than complain, Apple figured out another way to skimp on costs. Seems like they did the same on the 13 series. Now this will be the norm, with batteries needing to be replace once a year. Ridiculous.
My experience with Apple Support...so useless. C'mon...80% on 13 month old phone. THIS is just pathetic! Replace the battery!Lol, my 12 Pro Max is exactly 364 days old today, and its at 80% battery health with 345 cycles, and Apple says its 'in good condition'. They won't replace it unless its at 79%.
Ultimately I had to pay to get my battery replaced, and now there's a point on my phone where the color of the stainless steel was "rubbed" off thanks to the incision of whatever tool they use. Absolute bs service.My experience with Apple Support...so useless. C'mon...80% on 13 month old phone. THIS is just pathetic! Replace the battery!
Do you think the store would have replaced the device if you had brought up the repair damage?Ultimately I had to pay to get my battery replaced, and now there's a point on my phone where the color of the stainless steel was "rubbed" off thanks to the incision of whatever tool they use. Absolute bs service.
No chance, they’d just say it’s cospefyicnand is to be expected. This has happened before.Do you think the store would have replaced the device if you had brought up the repair damage?
But it’s the technician that damaged the phone while repair in process? Wouldn’t they offer to replace the device? I sent it my macbook pro for a failed logic board. I sent it in for a repair, and it was in a pristine condition. No dents or scratches on the lid or anywhere to be seen.No chance, they’d just say it’s cospefyicnand is to be expected. This has happened before.
The difference is that you went to apple directly. In my country, apple service is only through authorized service providers, so they can get away with it. I did report the case to apple on the feedback mail that you get after service, but I doubt it’ll do any good.But it’s the technician that damaged the phone while repair in process? Wouldn’t they offer to replace the device? I sent it my macbook pro for a failed logic board. I sent it in for a repair, and it was in a pristine condition. No dents or scratches on the lid or anywhere to be seen.
After the repair was done, I went to pick it up, only to notice that on each corner on the lid had a chip mark/dent. I asked the genius bar tech that this was not how I sent my macbook pro in for repair, they looked at the documents and the previoius genius documented that the cosmetic was very clean. They agreed to replace the lid at no cost.
Same went for my wife’s phone when Apple offered the reduced rate battery replacement, got the battery replaced, but noticed that the screen had some dust/deadpixel inside the screen. I told them that it wasn’t there before the repair. So they replaced the screen at no cost either.
I see. Thanks for clarifyingThe difference is that you went to apple directly. In my country, apple service is only through authorized service providers, so they can get away with it. I did report the case to apple on the feedback mail that you get after service, but I doubt it’ll do any good.
I mostly live by those principals and I have a 3 year old X with 444 cycles and 100% capacity per Coconut. It should be at the point where it needs to be replaced but isn't so I believe them to be accurate. Another guy here who does this showed his battery history and he had somewhere in the neighborhood of 1500 cycles on his phone and battery capacity was still well above 80%. I'm a light user and work from home with a charger in front of me all day. It takes zero effort to set it down to charge occasionally throughout the day and my battery is always around the 60-80% mark.So I've been living according to these principles and the result?
1.5 years old iPhone 11, 100% battery health
0.75 years old iPhone 12 Pro Max, 100% battery health (it has been used with MagSafe all the time)
1.5 years old Apple Watch SE, 99% battery health (but consider it's a very small battery that will degrade much faster)
