docprego
macrumors 65816
1,245
111
Henderson, NV
Ordered the Intelliglass Pro and installed it on my new 6S Plus. It looked like this:
There is a line on the left and right edge of the screen where the protector will not adhere. No matter how much I squeegee it or press it down,these lines remain.
Ordered a replacement and experienced the exact same problem. Other than this problem I absolutely loved the protector. Are all edge to edge protectors like this or can someone recommend a very similar product that completely adheres to the screen?
Thank you
Ordered the Intelliglass Pro and installed it. It looked like this:
Thank you
that go fully to edge ? just asking cus it looks like in photo it doesnt touch the edge. but in regards what you mentioned. i had two diff verizon stores install different brands and att and mine looked like this each time :-X
Yes it definitely is an edge to edge protector, this is the product:
http://www.amazon.com/iPhone-intell...s=iphone+6+plus+screen+protector+intelliglass
Are you saying you had this style of edge to edge protector with the black border installed?
o ok. i see now sorry about confusion. but what i was trying say is. i had 3 different brands. they didnt have border. they were just clear glass. they didnt quite touch the edge but they lifted up exactly like that.
I just ordered an edge to edge tempered glass screen protector off Amazon. The brand is called Daswise. Read the reviews and seemed legit. I had a Spigen edge to edge and experienced the same thing you are with the lines on each side. Couldn't deal with it. I'll post my results on the Daswise product once I receive and install it.
I took a long look at the Daswise last night. There are many reviews that seem quite satisfied. There were some that were not. I'll eagerly be awaiting your results.
When I had a silver 6 plus this wasn't as big of an issue because I didn't mind how the non edge to edge glass protectors looked on the white front of the phone. On the black front phone those types of protectors just don't look so great. The edge to edge protector absolutely looked perfect on my Space Gray phone (black front) besides those lines. You would never know there was a screen protector on the phone if it weren't for that. I should add that when the screen was on the lines we're not an issue but it was such an eyesore with the screen off that I removed it and got a refund.
I just put on the Daswise today on my space grey 6S and it's great so far. It aligns perfectly and I have zero bubbles. It's a great option if you're not as willing to pay up for the Ice Max 3D/Cinder/Imos/etc.
There is a thread here showing pics similar to yours btw:
https://forums.macrumors.com/threads/pictures-of-iphone-6-6s-glass-screen-protector-issues.1923452/
I would order a new screen protector or simply not use one. I don't use one for my 6 Plus since I like to interact with the polished screen more. In the past all my screen protectors collected smudges anyway
Those are some great pictures. Has me even more excited about putting this one on my 6s+
I will get it on Tuesday. I'll try and post pics as well.
That would drive me insane LoL. Had the same experience with the Spigen Glass one. Right now I have the one from Verizon on my phone which is okay for now. It's too small and I hate the way it still leaves the edges exposed.
I'm either going to get one of these edge to edge protectors that looks right or not putting one on the phone at all.
How are these edge to edge protectors with cases in general? I ask before I just got an Urban Armor Gear case, and also bought a Daswise SP and wanted to know if these two were compatible. Anyone use the same combo?
I would also like to know this. I haven't put a screen protector at all on my 6+ but I'm looking into one for my 6S+. Would like to know which is the most case friendly edge to edge screen protector out there. Thanks for any help guys
Daswise is case friendly because it's just a hair shy of true edge to edge.
My Daswise install resulted in exactly the same problem I originally posted this thread about. It did not adhere at all on the left and right edges, exactly like the Intelliglass Pro.
Very disappointed.
Very disappointed.
Is this for the 6S?
I installed my Daswise last night and it went on perfect. No adhering issues at all. Couldn't be happier. Take your time when you are putting these on. As long as you don't press down in the middle, you'll be able to re-apply if the alignment is off. I'll try and post pics of it tonight when I have a better camera on hand.
its more than likley not the screen protector thats the problem. I had both a daswise and a cinder that fit one iphone just like your guys pictures with the bottom left and right not adhering and then i slapped them on another 6s and they fit perfect.
