I agree. I took the protector I had on my 6 Plus which is not edge to edge and put its my 6S Plus. I got the same problem on the left and right edges I have been experiencing with these edge to edge protectors.From all of these issues with the 6s/6s Plus, I would assume the screen has changed ever so slightly. The curvature might drop off more steep than 6/6 plus. Not enough to visibly see, but many screen protectors are having this edge issue.
I wonder if the manufacturers will release an updated version. Kind of makes me question is having a S/P is even worth it for this generation of iPhones.
The Belkin one I'm using isn't edge to edge but it adhered perfectly fine to the screen; but it's not really the best choice. Can't win.
After all the frustration I've experienced trying to put one on my 6S Plus I've decided to forget about it for the first time ever. And wow is it nice using the phone with just the naked glass. I never realized what I was missing.
Maybe bring it to a store that can apply the glass protector for you? The Oleophobic anti-fingerprint coating on all glass protector makes using the phone a better experience imo..
I'm using a daswise screen protector on my 6s plus and I also have zero bubbles, just a perfectly protected, beautiful screen.
I highly recommend the Benks ultra thin .2. I've had one on my 6 Plus for 10 months and tried the Daswise for my 6S plus but they (tried 2) were just awful. I couldn't get them to adhere without some edges showing. I went back to the Benks and couldn't be happier. The Benks isn't one of those 3 D protectors with the cupped edges. But it is so paper thin that it really does install beautifully. For my 6S plus it took me 3 tries to get my alignment right. Even then it adhered just perfectly.I dislike the way that standard tempered glass screen protectors look on the iPhone 6. Due to the curved edges of the phone, screen protectors can only adhere to the viewable screen area, not the borders surrounding it. So when I heard about edge to edge screen protectors I was eager to try them out.
Intelliglass Pro: didn't adhere to the left and right screen edges.
Daswise: didn't adhere to the left and right screen edges.
Makes me feel like these manufacturers slapped a 6S or 6S Plus sticker on them without every actually testing them.
Can anyone without hesitation recommend one that adheres to the entire screen?
Looks like I'm not the only one.I am running into this issue with my current phone and have wasted some money buying several tempered glass screen protectors because they all produce the same results.
I do not think that the curved screens between the 6 and 6S are necessarily different. I think there are inconsistencies in the curvature of the screen from the manufacturing process. I have applied the same screen protector on three different 6S screens using the same brand. One sticks perfectly, while another very well. The last one (my phone) looked terrible like the photos posted here. I have since then gone through three of the same brand, and one from another brand and the results are exactly the same.
Still looking for one that works well without spending much more money on this...
