To my understanding, there are several USB-C cables available, starting with four wires. These cables are suitable for delivering 4.5W of power and are likely used with toothbrushes. It is possible that you already have one of these cables.More questions. It certainly doesn't require *Apple's* C-to-C cable. What cable is needed, can it be one that supports USB 2.0 data speeds (480mbps — even with the limitations, seems like it should be adequate for lossless audio) or is a "better" one required?
Will USB-C audio work with any other (non-Apple) devices? Can I plug it into a Nintendo Switch, for example, which supports USB-C headphones?
Doubt we'll know about that until the update is out and people have a chance to experiment.
The next type of cable has an additional wire for USB-PD communication. While some inexpensive cables may resemble this design, Apple typically includes a cable with two more wires for USB-C 2.0. This configuration is sufficient for audio and USB-C 2.0. Additionally, the Thunderbolt device has four more wires.
