So Lightning lives on in a hidden, cursed form!
I noticed that hole in MKBHD’s video and wondered if that hole was a pin release. Wish they would just stop it with the proprietary connectors, though.
I get needing a lock on the headset, seems like you could design a mechanism to lock USB-C! Like an indent on the cable. Maybe they didn’t want people plugging it straight into the wall, because maybe the battery has some other voltage regulation hardware? Only a matter of time before the EU gets pissed, which works out for Apple because then everyone will need new battery packs.
They should have made this a generic USB-C battery pack, and increased production. Then non visionOS users would buy it too
I suspect that bit about not plugging it into the wall is the main reason. Or into a computer.
I suspect it's more than just a battery pack and most likely manages all the power for the headset.
Which is why Apple calling it a "woven USB-C cable" is so funny 🙂
And I don't think it is to reduce cost. I think Apple wanted a strong locking mechanism on both sides and USB-C wasn't good enough.
USB = "Universal Serial Bus" = cable, not the connector.
It's likely a USB cable, but with these proprietary connectors, and as another said, it's probably for a good reason of super-efficient power management to get the most out of the battery.
The Lightning connector is much more durable than the USB-C connector, which over time becomes lose and makes a bad connection.
Hard to know if it’s the cables or the actual ports. Sometimes a cable on my old MacBook Pro would click and sometimes it wouldn’t. 🤷
All I know is that my TimeMachine drive disconnected too many times on its own!
Makes me very wary of upgrading to an iPhone 15.
I'm guessing that the design considerations were:
1. They don't want a completely fixed cable so that the items can be repaired/replaced separately.
2. They don't want an easily detachable cable so that it's not coming unplugged during use.
Still it seems like a weird design. Here is this external battery pack that really has no design limitations or constraints dictating its design, it just has to fit in your pocket and connect with a cable...and they end up inventing an entirely new connector just for this? So odd. Seems like they don't want this battery pack being used for any other purpose, which some crazies would absolutely do if the thing had a USB-C port.
I had the exact OPPOSITE problem! I was a huge Lightning fan, but after 3 failed Lightning connectors on iPhones, I'm happy to see it retired. Even my current iPhone 13 Pro won't make a Lightning connection for charging, just months after getting it, and i'm still paying off the darn thing! Only charge via Qi now.
Lightning was a failure in the end.
I haven't had a single problem with any of my USB-C devices.
all my USB-C ports on intel macbooks started to get wobbly after 2-3 years of use, to the point the drives would disconnect when you moved either the drive or the macbook
they went just a little bit too small with the design. something between USB-A and USB-C in size would probably be way more reliable.
lightning has its physical limitations, but only issue with reliability was that the port got dirty with the dust from my jeans. needed to remove stuck debris from the port with a paperclip or SIM card key every couple months and it was back to working as new.
  • Angry
Reactions: Victor Mortimer
