kaycrystal626
I am sure Anker will come out their own Vision Pro battery pack for $100!
And triggers uncomfortable feeling too just by looking at it.
DING, we have a winner.My guess is that the Vision Pro requires multiple voltages (the displays separate from the camera systems separate from the M2) and all of the power circuitry is part of the battery pack and those pins are the different voltage rails.
You are right. I’m not referring to the Lightning interface (slow) but to the design of the connector.Then it’s totally apples fault to not innovate their proprietary lightning cable to be much better than USB-C counterpart in the past 10 years, for all aspects. MacBook is not charged via lightning. Mac is not powered by lightning, just two examples.
That’s been happening to me a lot. The receiver becomes unstable sometimes, and I suspect it’s the bad contact of the connector. And I’m very careful with it.So true. I have never had a bad connection with my Lightning version iPhone in the car, but it’s about 50/50 and having to constantly replug to get CarPlay on my 15 Pro
200 dolaros for 4 AAA batteries
I would look for a third party cable and battery if Apple made a USB-C power cable. USB-C will fall out at the drop of a hat. Remember the biggest weakness of USB-C is that it’s a crap connector that‘s poorly designed so that the cable falls out easily over time. You want a locking cable on both ends, so that neither side falls out. Imagine almost finishing your work you’ve been working on for eight hours and just before you hit save, you turn to the side and your arm knocks the cable out of the headset and it dies. Whoops, no more work.There's no way I would buy this without being able to directly connect it to a non-proprietary battery and to a USB-C port for display. Can you imagine any monitor half this price (or quarter or an eighth) not being able to be plugged into mains or into other devices for display?
If it only has one port, how would you plug it into the wall or charge the battery while using it?of course they could use just one USB-C port for charge and discharge, but they had to use two to make sure battery pack is proprietary
at which point fanboys realize the company that favored good product design is simply gone?
The only reason why someone who hates Apple hangs out on MacRumors is because they are a troll.Never ever had a USB type C loose connector. As for why apple choose this connector instead of type C, it's obviously to force users to buy those expensive power banks from Apple. Apple always doing everything for profit at the expense of consumers. That's why I hate Apple, and that's why EU should f*** them for this!
It's locked in place so the cable doesn't disconnect while it is in your pocket. Even if it were USB-C it would require a fatter plug so you could lock that in place.I'm sure it's locked in order to be able to say "it's meant to not be removable we are not obliged to use USB" so they get to use their so loved "lightning" connector.
For purely environment reasons of course. 😅In a few years this won't be in the box 🟢🌏
Weird flex, but ok.l used a SIM card push pin to "unlock" the cable connected to the Apple Vision Pro battery pack. It popped right out.
Yeah why not 2 USB-C ports? One is not enough? 😁Why not USB-C port? Apple sucks.
