I'll suggest it's you that has to be a lot less aggressive with your replies. What you suggest you said was not what you implied in your original reply.
However, regardless of that I am peeved off. I love my music and I am a bit of a self-confessed audiophile. Removing the 3.5mm jack will be a massive inconvenience to me.
I currently own a pair of B&W P5 Series 2 headphone which I use daily. They set me back about $500. My other set of earbuds which I use for fitness are a pair of Shure SE425 ear buds. Both of which use 3.5mm jacks and both of which will out-perform any of the "Beats" junk that Apple is churning out.
Quite frankly I'm beginning to lose my patience with Apple as of late and the sheep that follow them. I'm amazed people aren't smart enough to realise this has nothing to do with "quality" or so called "moving forward with technology", and everything to do with making money.
- Having to replace technology forcing users to upgrade to create revenue.
- Making it inconvenient to keep using old technology to push them to replace creating revenue.
- Making users buy adapter to keep their current technology, creating revenue.
- Licensing the proprietary technology to create revenue.
There's absolutely no doubt Bluetooth has its place. Cars, and headphones too, but it also requires power, therefore charging, therefore total inconvenience to the user and higher cost.
I use my headphones all day long at work, and on flights, and at home. I use them for at least 8 hours a day. The inconvenience of having to recharge them is beyond annoying and impractical, and then I'd love somebody to answer me and tell me what happens when the battery eventually wears out. Do I simply throw away a pair of $500 headphones? (I've had my Shure's for almost 7 years now and they still sound as good as the day I bought them). I can't see this being the case with a set of Bluetooth earphones.
Are people so stupid / blind to see this?
We're just all suckered into an oblivious blackhole of consumerism and it really is beginning to piss me off.
So; To answer your final statement. No I won't relax as I stand to lose a significant amount of money and the only organisation that will gain from this is Apple.
We all lose.
