familychoice
I push my M1 Mini pretty hard, but I can’t recall ever hear the fan kick in. I didn’t even realise it had one!
Over the past years Apple's Macs have become esteemed in part for their silence, to the point that turning on some PCs can make one wonder if the startup sound ought to be 'Cleared for takeoff!' In that Apple is a victim of its own success; now people expect silent computers from them.Pretty sure this is nitpicking for a particular line of work and its workflows.
This. I didn't even know my 2020 M1 mini HAD a fan until about 2 months ago, when it came on very lightly during a video game.I have an M1 mini and heard the fan for the first time last week after owning it for years (I was processing a few 4K videos with full CPU and GPU load). It caught me completely off guard. The case for the M1 and M2 mini was clearly designed for the thermal needs of Intel Macs (my 2012 Quad i7 would constantly push the fan) and was way overkill for those chips. With the M4 I guess Apple finally decided to scale back the thermal mass of the device to match the actual requirements of the M4 series SoCs. It shouldn't impact the reliability or longevity of the chips, but will probably lead to the fan being heard more often, unfortunately.
don't know what if anything this tells you but,
on 16" m4 pro running in clamshell mode it takes about 250 tracks of "NewLogicBenchmarkTest" to get the fans audible at all
around 300 tracks, after a few passes, they ramp up to the point you can really hear them
not very scientific by any means but haven't had time to really try anything else and figured I'd share anyway
this is with "high performance mode" on btw
Agreed. Which is why I wish they didn't shrink it.This is for M4 Pro and I can tell you the old M2 Pro model is not as quite as the base M2 either. You have to make some compromise to put high performance chips into small form factors like this.
Wait… does this mean I can’t run cinebench multicore benchmarks 24/7 in my home studio while doing vocal takes. No deal! 😝The fan on a Mac mini isn’t going blow hard enough while do vocal takes to be an issue
Only if you are recording live off the floor in the same room with extremely sensitive mics. If you put this in a control room or in a ventilated isolating case (we used to do this with Mac Pros) it is not an issue. I suspect the problem lies with the low-budget use case. I mean, it is a mini after all…Wouldn't a low noise floor be important in Music production? I would absolutely think so.
I’m curious about the tracking comment. Why would you not use closed-back headphones where you can literally isolated everything in the playback? Or are you referring to noise in the signal chain prior to mic input?My current machine, the MBP M1Pro is silent. Probably heard the fans once.
The AudioRepair portion of my work is a bit demanding. And tracking issues in audio files (hums, hisses, etc) requires a quiet environment.
And fan noises can be quite annoying - no need for a silent room.
Audio Repair, tracking, mixing, etc…it is better in a (mostly) quiet environment.
You go to the extremes but clearly never had to spend 8 hours working with sound.
I’m sometimes annoyed by my phone vibrating or the faint noise of the mouse against its mat.
To each his own.
Fan noises on these machines is probably not a deal breaker.
But it’s one of these tiny things that I like to keep to a minimum.
I’ll wait for some more feedbacks. Although I will still probably pull the trigger at some point.
Hitting the play button on your Mac is not going to make the fan kick in.Well I have a set of floorstanding speakers that I prefer to listen to music on.
I’d say it’s critical for me to have a quiet environment.
I ditched many gear over the years just for that reason.
But it’s still a solid option. Just maybe not for me
I think at this point my question is
What tool is currently in use to do what the mini would replace that is quieter than the mini?
I'd say you answered your own question here, just don't buy one. Though I still don't understand your reasoning. Not trying to be disrespectful but you are making a mountain out of a molehill.I, for one, am worried that the M4 Pro Mac Mini would be too loud too often for my use cases. Recording is not my main grip here - I should not pick up the fan noise when working at my desk.
But when repairing audio, mixing and mastering, I’d say it’s critical for me to have a quiet environment.
Ignore me...Not sure if it’s because I had already seen this post, but I can detect the fan noise from the new mini. I am not going to do much video/audio/photo editing so I’m not concerned but it is definitely louder than the mac mini m1 it replaced.
The only times it seems any mac gets actually obstrussive in noise is when cpu/gpu are both taxed, or as pointed out above, 300 tracks after a few passes of Logic benchmark test and that was a m4 16" macbook. I'd wager the thermals are better in the mac mini over a macbook too. You've pointed out recording is not an issue, so what is so computationally intensive in mixing that is going to stress such a powerful machine out? I doubt audio restoration and mastering is going to do it.
Remember when we had real issues like having to defrag your hard drives every week and before every recording session. Having to use send fx aux and sending channels to busses so you could apply fx without bogging the system down or using stupidly high buffers, and this was only a few fx. Trying to record multiple channels at anything over 16/44 or 24/44, forget about 24/196 in a home studio. These were real issues, and do you think the PCs/Macs were silent back then, lol. Now we have so much power and can run a hundred tracks at 24/96, running softsynths and dozens of individual fx on tracks, all in your home and these tiny systems don't even break a sweat. As nathansz asked above, what are you actually using now that is quiter? I use 6 big fans at very low rpm to keep my PC cool and quiet (still around 30-35bd) but the tower is simply huge and I want space.
And if noise is really that much of an issue, put the mac in another room, you can use wireless keys/mouse and run a cable for the monitor, or just do what I do and have a box lined with some acoustic foam sit over my PC with the opening facing away. You either need this much power in which case there is solutions (though I believe there is no issue here and is why i am actually buying a Mac for the first time ever), or you simply do not need this power so trying to justify it by making this a big issue for you, which is fine. Noise in a studio is not a new thing and there are many workarounds that have been made over the decades, but one thing is for certain, computers today are much quiter than they were in studios 10 years ago, let's not even start on 20 years ago.
Yeah, this is what I expected for the M4 Pro model. The heatsink/heatpipe solution seems very small for the M4 Pro. I'm also doing audio work with Logic Pro, and having a noisy fan ramping up and down during projects is not ideal.
"So what? Get a Mac Studio then!" Well, this is an issue that should't be, if Apple hadn't been overly aggressive with their design, as neither the M1 or M2 Pro Mac Mini hardly ever made a sound.
I got a lot of hate for pointing out the obvious in my other thread, but there you go..
Still looking forward to some more youtube reviews. I want to ditch my i7 Mac Mini, but might be forced to wait another 6 months for the M4 Mac Studio (even though I don't need the added GPU cores on the M4 Max chip).
Do you need the Pro? I run Ableton with Maschine as a plug-in sometimes (two DAW's at once!), which is a pretty hefty workload and my M1 Mini handles it fine. I run Logic with a bunch of plugins too, again without any issues.Yeah, this is what I expected for the M4 Pro model. The heatsink/heatpipe solution seems very small for the M4 Pro. I'm also doing audio work with Logic Pro, and having a noisy fan ramping up and down during projects is not ideal.
