metanoiaway
this guy does a nice review and talks briefly about thermals, favoring the m4 pro
As a comparison, my M1 Mini makes no sound what-so-ever.The hang wringing over precision audio engineering versus fan noise from a $1500 computer seems ludicrous. If professional grade is what's needed then perhaps a consumer grade device isn't appropriate.
What is hang wringing? Nobody is talking about professional grade expectations but ludicrous is getting rid of a form factor that worked and sacrificing form over function so that it makes the device questionable use cases that you don't understand.The hang wringing over precision audio engineering versus fan noise from a $1500 computer seems ludicrous. If professional grade is what's needed then perhaps a consumer grade device isn't appropriate.
I hear you and certainly Apple is going to work hard to justify that $2,099 or so starting price for a Studio (my guess is price goes up $100). That struggle might be one of the reasons why its release is so delayed. But there is also some real physical limits to how much processing can help certain workflows. I think M4 Pro mini has basically reached the point where it can satisfy all levels of still photograph workflow. Now even the Studio maxed out can't satisfy all levels of video or 3D workflow as that just can take whatever you can throw at it. Pros will still buy Studios because that extra $700 might be one-day's work for them. But it might take something special from Apple like 48GB RAM and 1TB SSD in the base Studio to get enough folks to go to that $2,099 level.Like in the past, the M4 Max chip in MBPs and in Studios will be far more powerful, including available 2X RAM, 2X memory bandwidth, more cores, etc. Just look at how much larger the M4 Max is physically, and look at performance testing. I agree that the M4 Pro is going to satisfy a lot of needs, but when/if M4 Studio is released my guess is that most users that could save a few bucks with high-spec Mac mini Pros will decide that the extra breathing space of Studios' much more competent Max chip is preferable.
My M2 Pro only turns its fans on regularly with gaming (Baldur's Gate 3 specifically). Still quiet even in a gaming session, but I get audible fans. Office work does nothing to it in terms of fans.As a comparison, my M1 Mini makes no sound what-so-ever.
It looks like every Mini since then is a step down in the noise department.
You appear to be ignoring some important facts.I’m currently using a MacBook Pro M1 Pro. Silent as it is. It’s a beast. So yeah. I answered my question a long time ago : this MacMini is probably not for me but it’s a great machine. Can’t emphasize this enough.
Just because you asked, here is, for instance, the latest session that put the M1 Pro in overdrive.
A 60+ tracks project for a theatre. 10 multiouts Omnispheres/Trilians. 10 Kontakt instances. 7 ARCADE libraries. About 25 audio tracks (vocals, guitars, etc). And about 10 stock instruments.
Every single track with complex automations. About 25 different buses.
The project contains about 11 alternatives (half for incremental variations, half for multiple purposes such as studio mix, live mix, pre master, promotional mix, etc).
And multiple I/O insert/return points with some digitally recalled hardware.
The MBP struggles a bit but stays quiet - even when bouncing realtime with a heavy mastering chain.
Now. I might be wrong. But should the MacMini go into fan noise mode during these sessions, it would be a pain at the end of the day.
Again. My use case. My issue. Not ranting, not demanding. Just saying!
The MacMini M4 appears to be a mini studio on its own right. And I’m pretty sure it’s up to the task. Just not mine!
The M4 is massively more efficient than the M1. You're not running benchmarks that will consume all available power, you're running an *actual workload* which is roughly constant - that is, increasing the available power of the CPUs doesn't increase the power consumed by your workload. That means that running on an M4 - any M4, regardless of cooling - will run cooler (in other words, generate less heat, regardless of how that heat is removed) than on the M1 by a notable margin.
Beyond that, it appears that the fan in the M4 is not smaller than the fan in the M1.
So there is really no good reason to think that you're going to get louder fan noise in the M4 Pro than in the M1.
Sitting on the fence for this probably imaginary reason is nuts. Go buy one and try it! You have until January 8 or so to return it.
The hand wringing over precision audio engineering versus fan noise from a $1500 computer seems ludicrous. If professional grade is what's needed then perhaps a consumer grade device isn't appropriate.
Mate, you aren't pushing your computers if you dont hear the fans, no matter what you think.Very surprised to hear this - given there was backlash over the M1 Mac Studios (which they fixed with M2).
I never hear the fans in my M1 Max Macbookj Pro nor in the M2 Max Mac Studio.
I see you are very opinionated about use cases that you don't understand. Thanks for the input.Maybe or maybe not. Most of the stuff in studios I've seen is rancid old mac pros coated inside and out with a unique amorphous combination of dust and nicotine. If you do anything even remotely stressful on those the fans scream in agony "killlll meeeee". No one cares until they die of natural causes. Then everyone gets uppity about exactly the same kit not being available 10 years after they last bought it. That and macbooks of unknown maturity (but old enough to have a light up logo) held together with duct tape and more nicotine.
Any mac mini is better than that crapfest.
Personal studios everyone gets really 10x more uppity about. Literally everything is micro optimised to never produce anything musical whatsoever because they are too busy whining about fan noise on something which you can't hear anyway and staring at microphone reviews, which is pointless because they can't sing anyway.
Also the biggest contribution to the noise is the sound engineer's farts which are definitely louder than a mac mini fan.
Edit: to keep it quantitative, I've just transcoded about 2h of 1080p on mine (using CPU not hardware codec on handbrake) and I didn't notice any audible noise at all. Then again I'm old and can't hear certain frequencies - like whining people.
Initial impressions of your impressions are not very good.ok, so this afternoon I've returned the base M4 and got the base M4 Pro. Did my usual quick Dota 2 test and I have to say I'm disappointed with the noise. Here is the breakdown:
M4 base - max settings, 60fps = zero noise
M4 Pro base - max settings, 120fps = a lot of noise - not as bad as my 2017 MBP Intel but its still VERY audible.
However, if I put a cap on fps to 60fps (basically the max the M4 base could reach) then the M4 Pro is silent also.
Last 24 hours with the base M4 I never heard the fans.
1 hour with base M4 Pro and I already heard a very loud fans.
Now I'll do more testing but initial impressions not very good
What was said makes complete sense. The m4pro has 16 gpu cores compared to 10 on m4, and double the performance cores (8 vs 4). There will be more heat generated at maxing out the m4pro that will ramp the fans up likely to a level that may not be attainable on the m4 due to much fewer cores and thus heat. It seems the m4 maxed out did not attain audible levels of the fans. The video game test is what’s telling — not the anecdotal comment about using it for 24hInitial impressions of your impressions are not very good.
Seriously, this is profoundly ridiculous. "I tested my M4 by running the screensaver for an hour and heard nothing, then I tested my M4 Pro by running cinebench on a loop in the background while running a batch transcode of 10TB of movies and I heard lots of fan noise, I'm so disappointed." Does that make any sense at all? What you did is not as extreme, but still very much like that.
Now. I might be wrong. But should the MacMini go into fan noise mode during these sessions, it would be a pain at the end of the day. Again. My use case. My issue. Not ranting, not demanding. Just saying!
You can also see the Pro is copper.I did find this image online where you can easily see the difference in cooling solution, the pro has a much beefier heatpipe and looks like twice as many fins to deal with the extra heat. Though from what I am reading now, even it does appear to struggle to keep heat in check in some use cases. Where this performance fits into audio/studio use (since GPU use is barely used) is a bit unknown as yet, so yeah thanks for questioning it as I am gonna wait a few weeks and see what else is discovered now.
Why Apple is using that tiny blower that looks the same size as the macbook blowers, I don't understand. If they used a larger one, or even the dual fan design from the studio, it could move more air at lower rpm with less noise.
All the Mac Mini reviews on YouTube I am finding are brutal
