simontaipei
thanks! but i got this message for the second input into the terminal..
/System/Library/Extensions/USBCDCEthernet.kext failed to load - (libkern/kext) not loadable (reason unspecified); check the system/kernel logs for errors or try kextutil(8).
vlan-2638-10-16-159-210:~ MICH$
what went wrong?
Dear Sir,
I got the same problem please help
Chang-Shun-Yuteki-MacBook-Air:~ Simon$ sudo kextload /System/Library/Extensions/USBCDCEthernet.kext
/System/Library/Extensions/USBCDCEthernet.kext failed to load - (libkern/kext) requested architecture/executable not found; check the system/kernel logs for errors or try kextutil(8).
thanks!!!
