I've come to understand that this is shameless duplication in advance...Quite interesting that these and the homePod look almost identical![]()
[doublepost=1496884204][/doublepost]
Here is a screenshot from Apples homepage saying that two together will detect each other and work together for better sound.
Better sound does not equate to good sound. One could hardly envisage listening to something like Fauré's Requiem on a setup up such as this. I don't think Sonos et-al have much to fear.
Apple are taking audio 'downmarket' whilst at the same time charging the customer a premium for the privilege.
it is incapable of knowing the location of the listener, which is absolutely critical for such effects.
The Echo performs AEC on the microphone array, which takes multiple audio sources and uses DSP algorithms to locate direction and approximate distance of a source. At best Apple is [...] simply splitting the tweeters down the middle for left/right separation.
Don't waste your money on a Sonos 3 - the Sonos 1 has incredible sound for such a small speaker and is largely replacing the 3 in sales.But I don't think that's the point. This device isn't shooting for perfect audio. No matter what they say in the keynote, I don't believe this is supposed to be your primary home listening device.
Right now I've got a pretty awesome sound system paired with a TV in the basement, but most of my music listening comes from my mediocre-sounding little echo as my wife and I prep dinner, eat, and clean up. I think his will be a great step up for people like me who want decent sound, but whose wives aren't going to allow them to drag a speaker system into the kitchen.
I will need to check into pairing up an echo dot with a sonos 3, but if the sound quality is even close, I'll probably go for the all-in-one just for ease of use.
So basically you want a speaker light? what happens when you want to move the speakers? Rewire your whole house? You should really think before you type a whole paragraph of .
True. I hope you're right and that as the release date nears, we'll learn more. If these things can sense one another in the same room somehow and build a proper stereo sound stage, then I'd totally consider getting a pair for the living room. If they sound awesome and can play tunes without even having a receiver then that's a pretty clean, beautiful music setup.
There was a time where I wanted to be an audiophile, but the prices were just too stupid for sooooo little return. Can you get better sound? Sure you can, but you gotta put out exponentially more cash each time to get barely detectable sound improvement. I thought I hit my "good enough" level long before I hit the right to call myself an audiophile. Regardless, I'm pretty happy with where I am today, but I'm not ready to give up stereo.
// get offa my lawn.![]()
You can actually put together a pretty decent two channel setup with the Dot ($50), T-amp ($30), and Elac Debut B6 bookshelves ($279) or something similar. I suspect you would get much better sound quality from that type of setup and you could always add an inexpensive preamp later if you wanted to add more sources down the road.That's the point I tried to make earlier. The Echo Dot can be had for $40-50 and can be paired to ANY set of high quality speakers that will certainly be cheaper than Apple's $700 a pair for the Homepod.
Example:
Echo Dot + Vanatoo T1 = $550
A benefit for this type of config is you can place the Echo Dot wherever is best for picking up your voice, and place the speakers where the best sound is produced. And the Vanatoo's will play down low with aplomb without distortion.
Mind you that's a higher end speaker. Hell, the Klipsch Pro Media 2.1 is only $170 and change includes a "bass unit" (subwoofer kinda) which will certainly play lower and louder and be a fraction of the cost with an Echo Dot.
All in all, I don't see the the appeal.
Not me. I would rather have a great setup at home if I was an audiophile. There are a couple issues with live venues. First off, your seats may suck, you may be sitting next to a loud moron that wants to scream every lyric, or the venue just isn't setup great for audio. In a lot of cases, they simply want it to be so loud that your ears ring for hours when you leave.For the price of a true audiophile setup, I think it would be a better option to listen to the music in a live venue. It's true that for audiophiles you're looking at diminishing returns on a logarithmic scale. For me, I think I fall under mass music concept in that since I'm not listening to FLACs unless I'm on studio monitors and most of my music library is comprised of MP3s, Apple Music, Amazon Music, and random WAV files for mastering. When I'm at home, stereo doesn't even play a real role. I just have multiple Sonos 1s all play the same Apple Music playlist and do things while I hear (not listen) to music. I do have 5.1 Sonos setups as well as stereo pair Play 1 setups but I already know that the sound is not really an audiophile setup and instead just streamed music at slightly lower bit rates. Even listening to FLACs or high bit rate WAV files on studio monitors doesn't equate to a live performance. I think if given the choice, I would go for live performances over a true audiophile setup.
In fact you could get a pair of Sonos 1's for the price of a single HomePod. I know where my money would be going.
But better isn't stereo. What I want to know is if for instance a drum roll in the recording begins to the left where the snare is and travels around the toms from left to right, will that replicate in this speaker? Will it if we have two of them? Or, will it just "sound good"?
I don't pretend to know how these things work, I just want things to sound right to my ears. In early Beatles recordings one instrument or vocal would be pushed entirely into the right or left channel. Will that be replicated, or is "better" now centralizing those elements and delivering them to me sounding "better"? Will the sound I hear sound like what the recording engineers wanted, or like what Apple wants me to hear?
I guess really the only thing to do is wait and listen to one (or two) when we can. Maybe all this is so much paranoia, and it'll all "just work" at which point, I will happily sit down.![]()
Some people can afford either of them. So a comparison, regardless of the price, seems reasonable toward informing a consumer whether or not the Apple device is 'worth the money.' If i have $500 to spend on a device of this type, why wouldn't i want to see how they compare to each other? If the Apple didn't sound as good as the Echo, i could 'save some money.' If the Apple sounds significantly better, i can decide if that difference is worth the difference in cost. What's "unfair" about this? There aren't that many similar devices. The HAVE to be compared to each other. This isn't like comparing a Bentley to a Chrysler 300.Apple has done a remarkably good job.But the price is a bit higher compared to the Amazon Echo, So why even compare to a product which is half the price of HomePod'
Sounds!! Unfair :-(
I personally hope it doesn't.Does anyone know if the HomePod will have a 3.5 mm line-in?
Congratulation !
Beside, why do peoples bother with buying 1080p LCD TV when I personally own a 70' 4K OLED TV.
Plus, Toyota is so stupid ! I own a TESLA, WTF ARE THEY THINKING !
Oh man, wait until you see the pool I have on the roof of my house, you wonder why they even make houses without it !
Peoples are so dumb! WTF !?!?!?
How does this sound "Unfair" if you never even heard the sound quality from Home Pod before? The Reason you say it "Sounds unfair", is because you have NO knowledge of what premium sound quality is. Because if you did, you would not be stating it sounds unfair.
I suggest you research other competitor products on the market with Bluetooth/home audio. $350 is not unreasonable for what Apple is asking when you factor the capabilities and performance, especially when other Bluetooth speakers range in price point higher than what Apple is charging.
It's difficult to grasp a new market category, but in 10 years people will fully expect their homes to be smart.
There are no ports on it. Only a static power cable.Does anyone know if the HomePod will have a 3.5 mm line-in?
Behold the state of reasoned discourse today!The problem is this product isn't smart. It's dumb.
My Carver speakers are over 21 years old now. I bought them when I was in college (it's called getting a job). When it comes to hi-fi, older doesn't mean crappier and a good pair can last half a lifetime. That's hardly comparable to ever-changing television standards and the latest/greatest computers. How many Mac owners on here buy a new Mac every other year? What's that cost? The Carvers were on closeout for $1175. That's not even a middle of the line 21" iMac. So I guess it depends on what your priorities in life are. If you need a $1000 iPhone just to do Facebook and texting and what not and think that's a "reasonable" price (as SO many Apple fans on here seem to think), why are you getting so upset at the idea that this Apple speaker is a joke (not even stereo)??? The Klipsch speakers I mentioned are around $150 a pair and I guarantee will blow away this Apple "pod" thing for a small to medium sized room.
Besides, if it were really about being poor, you wouldn't be on an Apple forum because Apple isn't exactly a brand that's all about bargain priced products.
[doublepost=1496970718][/doublepost]
One Apple Airport Express + Klipsch THX ProMedia 2.1 sub/sat speakers = $250. I guarantee that it will BLOW AWAY this POS for sound quality. Want voice commands? Add a FireTV to the room instead of the Airport Express (even if you don't ultimately use it for video) for $100. You're still at $250. You've got 4x better sound quality and saved $100. FireTV has Bluetooth. The Airport Express (if you can find one) has Airplay. FireTV + Kodi App installed will give you music Airplay as well on the FireTV. Why would I want this thing?
[doublepost=1496970759][/doublepost]
Here is the sum total of our interaction:You mean, like the way you ignored all the rest of his post and only replied to a single line?
As clearly indicated above, other unrelated posts were merged by the forum software, but I suppose this just serves as a corollary demonstration of the state of reading comprehension today.Behold the state of reasoned discourse today!
You're missing the point. People don't want a 6 device workaround. I'm not putting a 2.1 system, a fire tv, and an airport express on my kitchen counter. Of course you can assemble a better sounding sound system for cheaper if space is no concern. That's how sound systems have always been. But the homepod is an upmarket Echo. Eight million homes have Echos right now. It's pretty clear there's a market.
I think someone can't count. That's 3 devices and an airport express can be tucked away almost anywhere. If a kitchen counter is all you need, though, perhaps it would work for you. It's not hard to put speakers in most rooms, though.
