I did watch it and there's a difference in what "compliment" may mean and the idea of 2 being paired up as excellent stereo Left & Right speakers, as was the context of the conversation. Compliment could mean that they'll both sync up their sound output to try to generate about the same volume throughout a room (which is what I suspect it means). That's different than what stereo means in the context of the conversation. For example, does compliment mean the one to the left will optimize the stereo left channel and the one to the right will optimize the stereo right channel sound? Maybe, but that wasn't communicated. Of course, the trick for trying to believe it anyway is how would each speaker know which is left & right and the location of the optimal listening position to set themselves up that way?
Yeah until these are put through their places we won't know. That "self setup" is the key bit, if there is a wall behind the speaker it should be able to figure out L & R fairly easily. If the HP is placed in the centre of a room then L & R becomes a bit muddier and maybe "compliment" is what to expect.
But Apple themselves setup a demo area comparing the HoePeod to the market leading smart speaker (Echo) and a similalry priced smart speaker, the Play:3.
The Play:3 does have the ability to stereo pair - allowing users to form a basic home theatre system (with the addition of other Sonos speakers too). I don't think Apple is positioning the HP this way just yet (I'm going off the marketing, the words used in the Keynote etc. - speculation on my part). But... there is no reason Apple couldn't allow 2 to setup in stereo.
Looking forward to seeing more about these, and some 3rd party reviews on deeper functionality.
Bottom line: several people are suggesting that these CAN replace speakers in a good stereo or even home theater setup. The implication is buy one for the left and one for the right and they'll outperform classic speakers set up that way by working together. I can't absolutely refute that suggestion but I don't automatically buy it either... until someone can offer definitive information that "compliment" means that.
1. These people have never heard the HomePod - ridiculous to make a comparison.
2. They'd also need to define "good" (some people say the iPhone 7 screen is good, others say it is bad... good means nothing we need to define things to compare them).
I agree but that's the conversation within which I was participating. I suspect this in a fine smart speaker but it should mostly be left at that. Some in this thread seem to be trying to puff these up toward being the be-all, end-all speaker for ALL purposes. That, I don't believe at all but some puffery keeps flying. I figure by the time this thread ends, these will lay golden eggs, double as Star Trek transporters and food replicators and even slice bread (but only these slices of bread will be properly sliced).
Forums > Your Account > People You Ignore
It makes this place bearable and filters out the noise - it's usually the same few that are super critical or super positive without basis. I like using the forums for proper discussion, insights, info. The above feature lets me clean out the garbage posts from a vocal minority.
