MacRumors
macrumors bot
70,833
42,842
The new iPhone 14 Pro Max lasts two hours longer than last year's iPhone 13 Pro Max, according to a battery test conducted by Tom's Guide meant to simulate real-life usage.
In its review of the iPhone 14 Pro Max, Tom's Guide said that the iPhone 14 Pro Max lasted an average 14 of hours and 42 minutes on a single full charge. In a similar test, the iPhone 13 Pro Max lasted 12 hours and 16 minutes. On Tom's Guide's ranking of battery life in smartphones, the iPhone 14 Pro Max now ranks in 2nd place after the Asus ROG Phone 6 Pro, which clocked in at around 15 hours and 30 minutes.
In its testing, Tom's Guide found that the iPhone 14 Pro Max only drained 30% in 5 hours while downloading apps, listening to music, and taking pictures and videos.
Anecdotally, the iPhone 14 Pro Max fared quite well in terms of endurance. After charging close to 90% and then using the phone from 1 p.m. to 6 p.m. for downloading apps, playing music and shooting photos and videos, the phone's battery only dropped to 60%.
When it comes to charging, Tom's Guide'S test results fall short of Apple's claim that the iPhone 14 Pro Max can charge up to 50% in less than 30 minutes. Tests conducted by the publication showed it only charged to 42% from 0% in half an hour.
Unfortunately, the iPhone 14 Pro Max sticks with 20W charging, so there are faster charging phones out there. Charging a drained iPhone 14 Pro Max, we got to only 42% in 30 minutes; Apple claims you can hit 50%, so we'll be retesting and updating this review. By comparison, the Galaxy S22 Ultra got to 58% in 30 minutes with its 25W charger, and the OnePlus 10 Pro reached 93% and got to 55% in 15 minutes, benefitting from 65W charging speeds.
Compared to the iPhone 13 Pro Max, the iPhone 14 Pro Max does actually have a slightly smaller battery, but benefits from the new A16 Bionic chip and a more efficient display. Unlike the iPhone 13 Pro, the iPhone 14 Pro features a more advanced OLED display with a variable refresh rate of as low as 1Hz, as opposed to as low as 10Hz for last year's iPhone.
On top of the more efficient OLED panel, the display is now controlled by a new display engine embedded in the A16 Bionic chip that mitigates power consumption and features like ProMotion, Dynamic Island, and the always-on display.
Reviews of the iPhone 14, iPhone 14 Pro, and iPhone 14 Pro Max were shared earlier today, offering a more detailed look at Dynamic Island, the new 48MP Main camera, the always-on display, and more. The iPhone 14, iPhone 14 Pro, and iPhone 14 Pro Max will begin arriving to customers on Friday, September 16.
Article Link: iPhone 14 Pro Max Lasts Two Hours Longer Than iPhone 13 Pro Max in Battery Test
My experience with Android devices is that once you have a fast enough charger, even like 33W. Then battery capacity doesn't bother you so much. A 10 min charge gives you enough juice to last a few hours.
Is this test including always-on display being enabled? Most of the reviews I’ve seen so far are pointing out to the 14 Pro Max battery life being the same or even slightly worse than the 13 PM with Always-On
EDIT: I think most of these reviews were about the iPhone 14 Pro, not the Pro Max. Seems like the 14PM has a better battery life compared to 13PM than 14 Pro compared to 13 Pro
It matters a lot when you’re not near a charger. If you work outside. If you go out for a long night. If you go to a festival on the weekend. If you go camping. I will always take better/reliable battery performance over fast charging.
My series 5 Watch with always on is equal if not better than my series 2 without was. So makes sense
Reactions: BvizioN
But not with always on display being used
it doesnt matter...those 2 hours are cut with AOD....so now you have almost the same battery life as the iphone 13 pro series but with AOD
Nobody can have this kind of battery life. My S22 plus without AOD have less battery life than 13 pro max...with AOD i cut 20% from battery life
If you are going to give this information, please provide the comparison to the 12 Pro Max as well as the 11 Pro Max or whatever that was called. People go 2 and 3 years and would like to know how the phone stacks up to the prior flagship units, not just last years. Whether it be the battery, the display, CPU, or the cameras.
Still a nice improvement If you know you're not going be able to charge all day turn off AOD. I personally think AOD is a nice to have not a have to have. I don't leave my phone lying on my desk or anywhere usually, so don't find AOD all that useful in my usage. I'd likely just leave it off and take the extra battery life, unless I was easily making it through my day with it on.
Here is some info I found not in the article.
iPhone 14 Pro Max: 14 hours 42 minutes
iPhone 13 Pro Max: 12 hours 16 minutes
iPhone 12 Pro Max: 10 hours 53 minutes
For those going from 12 Pro Max (at new which your phone is not anymore) the 14 Pro Max battery will last 35% longer than a brand new 12 Pro Max did. 3 hours 49 minutes longer. That's pretty significant.
Note the 13 PM lasted 13% longer than a 12 PM and the 14 PM looks to be 20% longer than a 13 PM.
Another video I saw showed a drain test over multiple usages. Not sure how Tom's Guide tests battery life to know the difference between their numbers and those below.
The 13 Pro Max lasted 10 hours 55 minutes
The 12 Pro Max lasted 9 hours 11 minutes
But in the drain test the 13 PM last 19% longer than the 12 PM. Without a proper drain test it is tough to know where the 14 PM will come in, but I would expect it in the 13+ hour range. But at 13 hours or so, that could be up to 40% longer than a 12 PM.
I don't understand their comment about 20W charging.
I own the 13 Pro Max and the maximum charging rate is 27W and with the 14 PM is supposed to be 30W
I use the Anker 45 W charger on the phone and my M1 iPad Pro 12.9 (which has a maximum rate of 38W).
This setup works really well. Anker has new 30W Nano III chargers for those that just want the quick charging.
See: https://www.theverge.com/2021/9/29/22700491/iphone-13-pro-max-faster-charge-times-27w-charging-brick
See for 30W 14 Pro Max:
People keep mentioning the always on display and it reducing battery life but if the phone is in your pocket or face down on a table or in a case that covers the screen, it’s off. Realistically, how often is someone going to have the phone face up locked, not in use? And when you are staring at that Lock Screen for hours, it’s 1hz consuming minimal power. I bet if you did a test with it off and with it on, doing nothing, their would be virtually no difference in battery life.
I’m not carrying a bag with a power bank in it around with me while I’m on a night out or at a festival. Just what fits in my pockets. I’d much rather my phone just last and not have to worry if I can order a Lyft home because my phone died.
My power bank easily fits in my pocket. Also, you have that MagSafe one that is quite small. Festivals usually last a few days, power bank is a must!
