Just picked up a MBP retina 256gb with 8gb of ram. With the coupons I had I ended up saving $280 on it. Thanks for all of the help! ImageUploadedByTapatalk1416873068.240085.jpg
Looks sweet! I'm sure you've noticed a great increase in performance as well.
Yeah it's so fast! I can't believe how much I can do at once. It starts up super quick too. Are you at all familiar with datpiff? I have a lot of mixtapes off of there and am not sure if I should transfer them to the new MB or not.
This afternoon I used mitigation assistant to transfer my files to the new MB. I did not transfer apps or settings. I went into disc utility and there are a ton of errors. I repaired them, but would I have been better off just dragging my files over from my time capsule? I'm a little concerned that junk from my old computer is on the new one now.
