Bit of a long story here, but I want to include all the details.
I went to pick up my iMac (signature) a couple weeks ago, and they also have this PowerBook (DLHR) for sale for "parts/repair". It was in good shape so I took it for $20. Came with a charger too!
I got it home and opened it up and noticed that the flex cable that connects the left side DC-in/IO board to the Logic board was disconnected partially! I pressed the connected back on really well and reassembled the machine. It boots up and I was able to get Leopard installed just fine.
I discovered the battery was an OEM Apple one, probably since it was a brand new laptop, and it would not charge/hold any charge. I quickly jumped on eBay and got a 3rd part battery from a known seller that I have had good experience with in the past.
3 days later and my battery arrives. I put it in the machine and go to bed as it was late. Sadly, the next morning, the laptop shows 0% charge. The battery came at 0%, which is odd. I opened System Profiler and it shows battery is installed, Not Charging. 2 cycles, 4200mAh, but 0% charge. I put in the original battery again to have a look and it shows 276 cycles. I open coconutBattery and it shows the same, with about 60% of original capacity left, but 0% charge.
I have reset the PMU, PRAM, and NVRAM to no avail. Also tried a different charger too.
This leads me to believe that the OEM battery, while pretty worn out, is likely still usable, but the laptop is simply not charging any batteries. So the new battery did me no good of course. I have requested a replacement from the seller in the off chance that this one was just DOA, but I have not heard back since the request yesterday. That said, I am not hopeful that it will work since I have two batteries here that seems to be fine, but can't charge.
Anything I can do to try and fix it without spending any (or very little) money? If not, anyone want to buy a pretty decent last gen PowerBook G4 that does not charge the battery? 1.67GHz, 2GB DDR2 RAM, 40GB (non Apple HDD) and 15 inch HiRes display.
Thanks in advance!!
Dustin
Thanks in advance!!
Dustin
