Ancandis macrumors member Original poster Feb 22, 2010 #1 After resetting my Mac mini with the PMU reset it - runs its fan on full speed - the front (power) LED does not show anything - SMC fan control shows "0°C" / "000rpm" Any way how to fix that? I did a PRAM and PMU reset again, but no go. Thanks.
fhall1 macrumors 68040 Feb 23, 2010 #2 Have you recently had the Mini opened up? Sounds like a connector is off.
Ancandis macrumors member Original poster Feb 23, 2010 #3 fhall1 said: Have you recently had the Mini opened up? Sounds like a connector is off. Click to expand... No, it has never been opened. The only thing I did was the PMU reset (unplugged all cables for 10 sec. and plugged the mains cable while holding the power button).
FrancoisC macrumors 6502a Feb 23, 2010 #4 Newer Mac don't have PMU if I remember correctly. You may have damaged your Mini by doing this.
A Alrescha macrumors 68020 Feb 23, 2010 #5 Ancandis said: The only thing I did was the PMU reset (unplugged all cables for 10 sec. and plugged the mains cable while holding the power button). Click to expand... Try unplugging it again, but don't hold the button in this time when you plug it back in. A.
Ancandis macrumors member Original poster Feb 23, 2010 #6 FrancoisC said: Newer Mac don't have PMU if I remember correctly. You may have damaged your Mini by doing this. Click to expand... Actually even two Apple Care employees told me to do so. Alrescha said: Try unplugging it again, but don't hold the button in this time when you plug it back in. A. Click to expand... Whoo-hoo! It worked! Thanks A LOT! 🙂
P phox macrumors newbie Sep 5, 2013 #7 Alrescha said: Try unplugging it again, but don't hold the button in this time when you plug it back in. A. Click to expand... Thanks. Saved me, too, 3 years later 😀
philipma1957 macrumors 604 Sep 5, 2013 #8 phox said: Thanks. Saved me, too, 3 years later 😀 Click to expand... that is cool
