Where exactly should I report this to ?
Apogee. Even if it is not their fault, I bet that will be the faster route. I am consistently blown away by their support.
Will Apple let you plug something into a Mac Pro at the store? Hopefully you won't need to load the accompanying software; I can't imagine Apple wanting to allow that. Or does the "guest" account solve that problem?
Just received a PCI-E Card for FireWire 400 and plugged my Interface in.
http://www.sonnettech.com/product/allegrofw400pcie.html
Sadly, it does not solve the problem.
Let's hope that this finally solves the issue alltogether... 🙄 😀 😛Looks like there's a fix for this...
https://www.macrumors.com/2010/05/03/apple-addresses-noise-anomalies-with-mac-pro-audio-update-1-1/
I've had this problem for years with my 2006 iMac (10.5 and 10.6, and even 10.4 i think) and a Firewire Audiophile. I got an Echo Audiofire 8 yesterday and hoped it would go away. It didn't. The awful noise is the same type as in seisend's example, except mine has pauses lasting about a second. Comes out of the lower vent too.
Will try the suggestions here, and anything else i can find, but i'm ********g tired of this. Was going to open it up (and that is not a fun thing to do with this machine) to find some way to silence it, but will try this first.
Managed to record and bring out the noise pretty well with a dynamic mic and some high-pass. How loud the noise is depends very much on how your ear is positioned wrt the speaker (turn your head to find the not so sweet spot).
Hello everyone,
Got a Quad-core 2009 Mac Pro running at 3.33 using w3580(was w3520).. question: How do I know if I have this problem also? My bootrom is quite different from everyone elses.. it ends in a B08 versus B07 OR B06.
MP41.0081.B08
I sure would like to know if I have this audio problem also.
Just make sure your Mac Pro is up to date.
Mac Pro Audio Update 1.1 by Apple Software Update fixes all.
Mac Pro Audio Update can't be installed on Snow Leopard(My start up disk). This updates requires Mac OS X 10.6.3 or earlier.. I am running 10.6.4!
So, now what? Or do I have the update already? I am certainly not going to downgrade back to 10.6.3 to do this though.. and 1.0 audio update barks and says: Computer doesn't require this update..
I think my bootrom has to do with this.. Again, I am not going to downgrade to either 10.6.2 to do 1.0 audio update or 10.6.3 to do 1.1, however I think I have all the updates because of my revised bootrom of B08.
