TheAppleFairy
Suspended
I'm thinking it will be more advanced than that.
More advanced wireless charging?
What battery case are you using?I'd take a battery case with larger capacity and the same size over this garbage.
My iPhone 7 Plus battery case is 4,000 mAh. This one is only 2,420 mAh. The battery in the iPhone 7 Plus is 2,900 mAh which means you don't even get a full charge with this Morphie case.
Will it catch on fire?
Same i always had a mophie for every iphone, i guess that email i sent out in August to include lightning connector didnt go through. Well i guess i can keep my 7+ on low power mode everyday still. I loved mophie....So with this case you can't use wired headphones at all.
Also if it can't do audio pass through USB then I'm assuming it's not possible to do CarPlay either. I truly miss having a mophie but they need to fix these issues first.
Yeah like roughly BT range or maybe slightly smaller. Like 10-20ft from a mini base station that is about the size of an iPad or MacBook charger on the wall for the first generation of AirPlug or whatever snazzy name they give it.More advanced wireless charging?
Yeah there have been some stories on here about that and the company Apple is partnering with that does that type of stuff.Gotcha, I saw some information about a company that was doing some wifi type charging but I didn't look into it that much. Knowing how transformers work and current induction technology they would have to do something completely different. It will be interesting to see what they come up with anyway.
I like Mophie Cases had one for a 5S. Never got one for my 6Plus.
I'm giving this one a try
iPhone 7 Plus Battery Case,Ruky 7500mAh Protable Ultra Slim Extended Charging Backup Battery Case Rechargeable Power Bank Charging Case for iPhone 7 Plus - (Black) https://www.amazon.com/dp/B01LY8PJ2K/ref=cm_sw_r_cp_api_oP4sybF5X27FS
It uses Lighting but you can't use the headphones.
It's got a little weight but feels good in hand. It has a magnetic back which is good for my car holder.
It can be a little tricky removing it at first.
It charged me from 50% to 100% in about 90 minutes but I was using the phone while it was charging.
Based on the LED indicator there was about 75% left on the case battery.
Yes i thought something was wrong with my phone for the longest time. I just ended up returning the product, i cant wait for a replacement, just bought a apple leather case (already peeling off 🙁 )I love the case for battery life but my down volume button won't work. I got a replacement and new one won't work either. Volume button works just fine without case or with my other simple speck case. Anyone else having this issue ? Ideas on fixing or just try again with a replacement ?
Why the ************ isn't the charger a lightning cable.
I hate Micro USB.
If not lightning they could have at least made it USB-C.
Do you know if that is true? Has anyone tried CarPlay with this case yet? I asked Mophie and they said it depends on the vehicle make and their implementation of CarPlay.So with this case you can't use wired headphones at all.
