There are several ad blockers that don't require root and don't care if it's 64 or 32-bit unlike how Apple restricts to 64-bit only to upsell. I normally use Adguard or Firefox with uBlock Origin add-on.
Thanks but the post you quoted was talking about ads on iphone..I believe the app was purify
I'm giving Apple one last release to get their act together in battery life. If iPhone 7 does not have significant battery improvements, that sexy new s7 will be mine.
For what it's worth, my 6s+ went all day and night for my normal use...
S7 edge I need a cord by 6 to 8 pm
Reactions: jayf and FFR
Actually the major drawback of Android is non software updates unless u buy new phones only. Depends weather u care or not about being up to date. These probably more guaranteed of constant and regular updated by the OEM for a while anyway. Where as with Apple, well no need to worry about that until the phone is discontinued.
You are guaranteed device stability updates or security updates almost every 1 to 2 months with Samsung...just don't think you're gonna get the latest major android software update .....I think that's enough though
Actually that doesn't translate into real life usage.
iPhone 6s Plus > s7edge relating to battery life.
One thing people kinda forget is that the S7 throttles faster than the 6s which saves battery but kills performance. Despite this ploy, the 6s still comes on top with a better actual performance too.
Your right Apple. Apple doesn't throttle the a9 like Samsung does with the s7 and the battery lasts longer. Standby or not it adds to a better battery life.
Samsung Galaxy S7 edge 98h
Apple iPhone 6s Plus 85h
~GSMArena.
Don't lie, S7 edge clearly lasts longer even without battery saving mode.
If you read my post it said with (my) normal usage, not some lab controlled test. I never even bought a car charger for 6s+ didn't need one...
FYI, again, if one could root this android phone one could more than likely get a very large percentage of battery life back by getting rid of unneeded junk..
If ya all think this is such a great phone..pm me in September..I'll be selling mine
Reactions: FFR
For every possible usage of both phones, the S7 edge lasted longer in all cases than the iPhone 6s Plus. Hundreds of reviews, videos and tests proved this. And you're here claiming that the 6s Plus lasts twice longer than the S7 edge!? TWICE!? how is that even possible lol.
[doublepost=1459257697][/doublepost]
So the S7 edge saves battery life by throttling, but even so, the iPhone 6s Plus with its lower mAh battery lasts longer without the need of throttling even though retina display is more battery consuming? is this correct?
Got a link for those, my google search is telling me they're about the same.
There's the snapdragon variant and then there's the exynos variant. The Exynos got an average rating of 98h battery endurance while the snapdragon variant got 87h. That's still two hours MORE than the iPhone 6s Plus. I'm guessing that they'll last about the same during daily use. But to actually claim that the 6s Plus would last twice as long is quite impossible.
Link?
Do the work yourself..your so overly interested in it..Google...xda, s7edge and battery drain..there's your answer..I made a statement based on my everyday useage...not some lab..how many times have I said this now...don't know, can't count that high
Oh ya...I never said twice the battery life...learn to read..my daily use makes me need a cord (battery charger) for the challenged. By 6 to 8pm on the s7...6splus would make it to midnight for me
