MacRumors
macrumors bot
70,488
42,184
Satechi today announced the launch of a new USB Type-C Clamp Hub Pro, which is made from aluminum and designed to work with the latest iMac and iMac Pro machines.
Available in Silver or Space Gray, the Clamp Hub Pro plugs into one of the rear Thunderbolt 3 slots on the iMac or iMac Pro. It offers three USB 3.0 Type-A ports with 5Gb/s data transfer and a Micro/SD card reader.
Setting up the Clamp Hub takes just a few seconds using an adjustable knob, and its slim profile adds little additional visual bulk to the iMac. The Clamp Hub is compatible with the 2017 iMac Pro, the 2017 4K 21.5-inch iMac, and the 2017 5K 27-inch iMac.
The USB Type-C Clamp Hub Pro can be pre-ordered from the Satechi website for $49.99. It will start shipping out in the first week of January.
Note: MacRumors is an affiliate partner with Satechi. When you click a link in this post and make a purchase, we may receive a small payment, which helps us keep the site running.
Article Link: Satechi Launches USB-C 'Clamp Hub Pro' for 2017 iMac and iMac Pro
If I had an iMac, I would buy this.
All my windows pcs have front facing USB ports, which I use a lot.
Even my monitors have easy-access side-facing USB ports.
Reactions: elev8d
Very cool. Ordering one (minus the affiliate link).
I'm curious why you go out of your way to mention the last bit - is there a problem with letting MacRumors get a few cents, if it costs you nothing?
(Note to folks "liking" this post and the other popular one in this thread: I'm asking a question, not leveling an accusation. That's why I start off above with "I'm curious why" and not "How dare you".)
This looks like a dam-good product. I find front-facing ports to be truly valuable and a function that I use quite often. I guess I am not one who loves groping around in the back of their computer looking for an open port for the sake of aesthetics.
Reactions: Chones cajones
That is a nice clever/minimal solution. I modified my older HiRise to have similar functionality...
There's a USB hub inside the HiRise. Unfortunately had to modify the HiRise, drilling out the holes/notches for the various cables. However, in the end I like a solution like mine a little better because it manages the cable mess as well. Granted, no SD reader in my solution, but could easily plug/swap one in.
The first reply pretty much hijacked the thread. I too am wondering why you would go out of your way to not support a site you obviously visit?
It would be nice if the next version of the iMac had ports easily accessible from the front or even from the side. I also may have to order one of these.
I agree. I like the visual design of the iMac, but I might has well have my work iMac on a lazy susan I spin it around so often to access the ports.
One wonders why Apple did not build this feature into the iMac Pro, a snap-down front-facing access port. I think they are addicted to the clean-front design and can’t see past it.
I'm curious as to what percentage of people here notice that every page opened on the site opens up to as many as 120+** connections to trackers/ads/beacons/etc.
I mean, surely the recent spate of in-line streamers and content-obscuring popups haven't escaped notice, but there's a reason for the duplicate posts, the non-news posts, the summary posts, the, the, the... – unless you're running an aggressive blocker, every visit here already generates income.
(** highest count I've seen was I think 138, about 100 more than the most aggressive newspaper sites out there, but I rarely pay that kind of close attention)
