After the AirPods
launched online and then
arrived to the first set of customers earlier in December, some users
have begun realizing that the charging case that comes with the headphones isn't holding Apple's advertised 24 hours of charge. In theory, the charging case should only lose noticeable amounts of charge when the AirPods are low on battery and recharging within the case, and when users flip the pack open to check battery levels or otherwise activate Bluetooth with a connected Apple device.
The unlucky set of users facing the battery issues, however, are
noticing that the AirPods case drains by upwards of 40 percent in mere hours, with the AirPods at 100 percent inside and minimal Bluetooth activation.
While some feared this is just the way Apple intended the headphones and companion charging case to work, Redditor
severinskulls has posted about his experience with the problem, and the replacement AirPods he got that do not have an apparent faulty charging case. In most cases, the AirPods themselves are not facing any shortened battery life issues.
AirPods Charging Case dropping nearly 50 percent overnight
The old AirPods Charging Case: The new AirPods Charging Case: When the AirPods first came out, the
initial impressions of the battery life for both the headphones and the charging case were overall positive. A handful of
MacRumors forum members were fans of the speedy charge rate of the AirPods, the granular settings of the iOS battery widget, and the battery life of the charging case as well. Mentions of battery drainage issues with the AirPods case began
about a week ago, around the time the first customers had been using the headphones for a few days.
In a
teardown last week by iFixit, it was theorized that the Charging Case was the cause of the AirPods'
delay from October to December. The root of the problem was a few empty spaces discovered within the solder joints of the case's chip. This is referred to as "voiding," which iFixit said "could be evidence of low quality standards, or a rushed product release."
The exact scope of the affected AirPods user base is unclear. Some users are theorizing that the problem could be an initial charge cycle hiccup that irons itself out over time, but some that have had the AirPods since day one are still posting about battery drainage with the charging case
today. On the other hand, there are many other users who have
reported normal experiences with the case and its advertised 24 hours of battery life. Apple hasn't commented on any of the reports.
Article Link:
Some AirPods Users Facing Battery Drain Issues With Charging Case
