There are a bunch of test you could do. Here are some:
CineBench - especially used for seeing CPU performance in rendering
I would recommend doing the following from idle:
1 run to get a base score, 5 consecutive to get a idea on how it performs when the CPU is warm
Another interesting test would be see the difference when using fan control software set to 100% (app 6000rpm and 5500rpm (left/right)) in the same scenario.
Then there is
Geekbench, which also is a great test and much more used. The great thing here is that there is a big online archive with all test date from the free version, so comparing performance on multiple identical devices are possible.
Here the same runs can be done, but seems a little much unless you have a high difference in the CineBench test.
also
Prime95 which should hit the CPU hard, but I have not tried that one myself yet, so I am not entirely sure on how it works and how to compare. I will do it later, but if some have more info it would be nice to hear.
For utilities you will need
Intel Power Gadget, this is an amazing tool to see power consumption, clock speed, temperature and utilisation of the CPU.
Some kind of fan control software, my favourite is
smcFanControl, last updated in 2016 but I have not encountered any problems with it on a 2017 MBP, so my guess is that it will work fine on the 2018 model.
Noting ambient temperature will also be good as to give an idea on environmental impact.
If anyone have some resources on rendering test in FCPX or its likes that is free to use, we could have a more comparative test across machines as we are testing on identical work mass on different hardware, giving us an easy comparison.
