More like people can’t read facts that contradict their snark.Did you see that the battery capacity may not be as small as we were first told?! People don’t read very far down in articles I see.
Why don't Apple simply make phones with decent battery like like they do in the Android world?
Lots of outrage towards Apple and misinformed people.
Wonder if the "outraged crowd" will stop buying Apple products in the future...
You see it all the time, too, these days. People latch onto the first narrative that fits their view and will only modify it under duress. Same with notable events: the press will latch onto something which may or may not be right and people will form an opinion. When evidence goes in a totally different direction people seldom change their views from when they first formed an opinion from the initial coverage.Right. It is hard to see that sort of info!
[doublepost=1547665289][/doublepost]
Ill informed people are so dangerous in socioety... Not just about batteries. Sigh.
It isn't completely stupid to compare electric current over time (Ah) when you know you are in a context were the output voltages are always the same.
But everybody should be aware that energy capacities be it of batteries, gasoline litres or yogurts is measured with energy units like joules, calories, btus (for all imperial fans) or you guessed it, Wh.
Energy is power over time. W measures electric (active) power, Wh measures electric power over time, ie, energy.
In short if Wh increases, the battery is larger whatever the Ah who may decrease or not.
Did something happen to Jony Ive?
It's embarrassing and saddening to see both the article and the comments here.. It just goes to show how low we have fallen in recent years. People are complaining and nagging about things even when they obviously have no clue on how it all works.
Amperes have zero meaning or value without knowing the voltage. What use is a insanely high amount of amperes if the voltage is really low? Same goes the other way around. It's almost like people would prefer to have a 10'000 mAh battery running at 1V over a batter with 1'000 mAh running at 10V even though the battery performance would be the same..
Talk about jumping the shark... The actual watts-per-hours in these newer battery cases are higher than the previous ones, still people act and behave like these newer ones are vastly inferior.... Get a grip......
He's too busy telling the iMac division that the 2019 model needs to be 1mm thinner.Did something happen to Jony Ive?
Sure, but since the iPhone 7 internal battery (7.45 Wh) was noticeably smaller than the Xs internal battery (10.13 Wh), even to get this somewhat smaller relative boost (75 vs 83%), you'd need a higher capacity battery case.The iPhone 7 case gave an 83% boost (22 hours when combined with phone, vs 12 for phone alone) to iPhone 7 internet usage time. The XS case gives a 75% boost (21 hours when combined with phone, vs 12 for phone alone)
I don't get it, why this case would not work on the iPhone X?
Isn't that the core customer group for a battery case. A case like that really makes sense once your iPhone has properly aged a couple of years?
All potential iPhone X customers will go straight to Mophie. What is this Apple, are you nuts?
1369 mAh capacity?? So that means it can only charge the iPhone XS for up to 50%? What a joke
Is this a joke?
Microphone and loudspeaker locations as well as camera bump size and location are all so slightly different between the X and Xs. One can argue whether Apple should have prioritised compatibility with older phones over perfect fit but specifically releasing new accessories for a product you already have stopped selling is rather rare.I don't get it, why this case would not work on the iPhone X?
A good analogy would be miles per gallon.
A 1969 Camaro SS with a 350 small block gets 10mpg at 290 horsepower.
A 2019 Camaro SS with a 378 small block gets 16mpg city, 27mpg highway, at 455 horsepower.
They're both semi-unibody coup ponycars, they're both rear wheel drive, they're both powered by small block V8s. Yet technology has advanced in 40 years to allow a much more powerful and capable car get better gas mileage.
So now you're getting a battery case that is more technically advanced than the ones from 3 years ago, that puts out "more power," while being "smaller" based on an old way of measuring things.
Well, that's what I've been using for the last couple of years. But apart from yet another item to remember to pack (incl. cable) and to stow away, it it is somewhat annoying to have both my phone and the battery pack in my pants pocket with the charging cable hanging out partially and getting hooked on vegetation, fences, etc..
P.S.: For me thus, a battery case makes sense to use on such days when I am outdoors for long stretches, and a relatively thin phone without battery case for all other days.
IPhones having been getting thicker....but you know "facts" right?!because it would likely require adding 1mm of thickness back to the device.
You think Johnny Ive is going to willingly let any device he works on get thicker? i was shocked when they allowed it to add 3d touch. but that was an exception to the rule.
for the last 5 or so years Ive's only been about making things thinner, even if it means sacrificing some functionality. Such as battery life in devices, Keyboard quality in laptops, or even structural rigidity of iPads
iPhone X/Xs: 7.7 mmfor the last 5 or so years Ive's only been about making things thinner, even if it means sacrificing some functionality. Such as battery life in devices, Keyboard quality in laptops, or even structural rigidity of iPads
All for the low low low price of 129. Apple is so generous.
But less convenient.
And run the cable from by the backpack to my phone? How is that more convenient? I'd rather have the cable as close and short as possible to my body.Why not just have a proper battery bank in your bag? As a bonus it also works with any other device you or your friends might have.
Horses for courses. There are advantages and disadvantages to battery cases vs battery packs, that's why there is a market for both.Because it can be used with any of your devices rather than a specific model of a specific phone?
Except for the fact that you can't stick this in your pocket and charge it wirelessly. I'm sure if this device was more portable, it would astronomically more expensiveFor about the same price something like the 160Wh Jackery Portable Power Station is more useful for camping, emergencies, road trips, etc. as it can charge the iPhone Xs about 16 times on a charge.
Yeah but in your car example "speed limits" are roughly constant over time, whereas with phones the speed they are supposed to run at increases exponentially.
3 years ago the battery cases were worth buying. Now they are not.
