Does it affect the color/brightness of the screen?
No I have not noticed any difference. I’m pretty happy with it. Will likely buy more to put on my wife’s phone and have some backups.
I tried the Tethys, is not a real 3D ful on Edge to Edge. It does not warp around the edges on the screen. I guess you can call it a screen protector friendly full screen protector, not edge to edge.is there a consensus ? iCarez vs Tethys?
Anyone using iCarez 3D can confirm if it works with Ringke Fusion?
iCarez TrueGlass Pro 3D. Took some work to get the bubbles out, but its all good now. Here are some pictures!
Any tips for install?
If their are bubbles just give them time, they’ll disappear.
That's some bad luck or bad batches.I’ve used icarez for the past few years and I have nothing but bad things to say about the 2.5D model this year. Ive gone through 8 (yes 8) of them and they all have the same defect where the top left corner won’t stick and now the bottom corners are starting to come up.
Where do you even get the Arbalest? The only link to it I can find is Amazon in Canada.Any consensus between iCarez 3D and Arbalest 2.5D? All accounts indicate that the Arbalest is the better protector, but it's only 2.5D and they don't make a 3D option unfortunately.
Buying my wife an XS and need to order one or the other in the next day or so.
I was able to find that one, but it looks like the model for the XS Max is only on Amazon in Canada.
Just curious why you think the arbalest is better?
