Odd! Rene Ritchie says it doesn’t work on X...
https://twitter.com/reneritchie/status/1085599654639734788
He is wrong. Probably so dead that the accessory didn't communicate with his phone
same design and more expensive... Apple learned nothing...
I would never, ever follow Ritchie. And to be on point for this topic, he was wrong. Others are posting shots of it working on their X.Odd! Rene Ritchie says it doesn’t work on X...
I mean, personal dislikes of him aside, he showed a picture that it was not working. He's not going to put his reputation on the line unless he's confident his doesn't work.I would never, ever follow Ritchie. And to be on point for this topic, he was wrong. Others are posting shots of it working on their X.
Agree he is still a smart guy regardless if you like his personality or not.I mean, personal dislikes of him aside, he showed a picture that is was not working. He's not going to put his reputation on the line unless he's confident his doesn't work.
That's only $10 more than the Mophie ones that are coming out, and these have wireless charging. Why is $129 so absurd?
Your comment implies the Mophie ones are good value...
And a $129 1st party battery that cannot even work without giving an error in iOS is pretty bad if that is the only issue with his.
He's using it on an X, while it may work or not work, Apple never listed it as compatible with the X.
You do know that the storage size doesn't increase the phone's weight, right? 😀
Battery case is not that high tech. Battery itself aren’t even worth much. The Apple Battrty Case’s battery is probably from one of Chinese supplier the same Amazon battery case use.
I have had buy some battery case from Amazon, they work just expected.
So you are saying battery case from Amazon will make you phone unable to make call? Is that what you saying?
[doublepost=1547647578][/doublepost]
I have no problem put these 50 dollar Amazon battrty case. Why not? It is not like battery cases are such high tech thing m.
Understood but other than software limited there is no reason it theoretically should not work like any other lightning cable plugged in
There appears to be some speculation on idownloadblog that it only works in the 12.1.3 beta on the X is why and Ritchie probably is not running it on that device.
Its really strange for Apple PR to get something like that wrong for sure.
And cover the camera? And who knows what antennas are behind the top of the back of the iPhone Xs that a battery going right to the top might interfere with.They literally just stick a battery on the back of a case. I'm sure they could modify the design of the battery so it fits the entire length of the case.
Anything that increases the price, even if only by a small amount from the product predecessor is seen by some as unacceptable.That's only $10 more than the Mophie ones that are coming out, and these have wireless charging. Why is $129 so absurd?
Rather than carrying this monster all day - I'll sit around 20 minutes with a $12 charging brick
But I have to admit being a donglemania-victim...
It may have occurred to you that a removable battery would match any use (and phone-) case ?Different use cases ultimately.
With a battery case, I imagine a possible scenario where you keep the phone in your pocket and the case will keep it topped off while you go about your daily business.
Then when you no longer need the case (like when it has been expended), you can remove it and still have a (relatively) thinner and lighter phone.
Unlike a phone with a larger battery (which in turn makes it thicker and heavier to carry around). I can’t strip away half the battery if I suddenly decide I don’t need that much juice.
The idea here is to not have to think about managing the charging of your phone. It just works in the background.
It might have occurred to you that a removable battery would match any use (and phone-) case ?
Except being The Forbidden Fruit in the (expired) Cookette Bible
Quick search on Amazon. Lots of battery case below 50 bucks. Yes, both this Apple battery case and Mophie one are overpriced.
I do agree. I'd rather carry a power bank of some sort in the bag just for emergencies, than make the phone bigger forever. Learnt this after owning a battery case. It made my iphone 6 unwieldy... I can't imagine how un-ergonomic the max phones will become with these on.
A slight improvement in the hump’s positioning and width has made a huge difference in the estetics.
Looks much better than the previouse Igore battery case.
