So you are saying battery case from Amazon will make you phone unable to make call? Is that what you saying?
https://9to5mac.com/2019/01/16/iphone-xs-smart-battery-case-capacity/
heh, all these smart cases have less capacity than the 6s/7 smart cases
Yeah but wait to see what the Mophie actually delivers. Given it wirelessly charges the phone there will be an efficiency loss.I stick by my initial BWAHAHA after 1369mah reported by 9to5, that is useless. Not even close to a full charge; maybe half a charge.
At least the Mophie mentioned by others for just under that price is 2000mah.
The iPhone 7 battery case even had a more sizeable 2365 mAH battery for $99.
Complete waste of $129. Less for more money, the new Apple.
And the SoC and power management IC in the XS are much, much more efficient than what's find in the 6s/7 phones.
That must have been a dilemma. There is a push/shift toward wireless charging, so you need space to include the coil and components. There is also the need to have a large battery to make it all worth it, but you can’t go high on the back or you’d block signal. And finally, you can’t make the whole thing too big to the point nobody would want it. All of that had to be factored in, so they had to settle on a smaller battery that would still make the project worth it.
Or I could be totally wrong. What do I know? I’m an accountant.
"This is significantly less than the 2365 mAH battery found in the iPhone 7 Smart Battery Case. The XS Max case features the same 1369 mAH capacity …"
Almost half the capacity for the 'max' sized model as the previous regular, no SoC efficiencies will make up for that difference
Specs on paper.
Apple lists the extended runtimes to be:
Talk time up to 33 hours*
Internet use up to 21 hours*
Video playback up to 25 hours*
Plenty of runtime.
Also, looking at how the XS Smart Battery Case is designed, it appears that Apple got rid of the hideous "chin" from the 6s/7 Smart Battery Case. They could have moved it up to just under the battery hump to minimize the size of the case. I'll take a bit of a hit in battery size to make the entire case not substantially larger vertically than the phone.
I mean there had to be some sort of something.Speaker holes confirmed!!!
Battery case delivered with 0% charge but seems to work and fit a iPhone X pretty good.
I would love to pay $130 for one! In Canada it’s $180!!!!
Images of Apple Smart Case on iPhone X. The area around the camera looks worse in this picture. In regular light it isn't that noticeable. View attachment 816000 View attachment 816001
