MagSafe ain't gonna happen. I understand it was a great connector, but it only had one purpose, and only worked on one device. USB-C is great in the sense that I can plug the charger into any of the ports (both sides) depending on what's best. I can also use any 3rd party charger, or docking station charger, or anything really to charge the computer. This is great! And a bigger benefit than what MagSafe gave us.
SD Card slots are becoming obsolete in the next years. So I don't see the point. Most professional cameras are going to transition to CFExpress in the next years. The change has partially already happened with XQD, and now that CFExpress is formally launching every professional camera manufacturer is gonna start moving to XQD/CFExpress. Only prosumer and consumer equipment is gonna keep on using SD cards ...
The number of cameras with CFast/XQD/CFexpress is actually shrinking. You find SD-only cameras in categories as high as the Canon R ($1800), Sony A7R IV ($3500), Panasonic S1R ($4000), Sony A9 ($4500), in medium format mirrorless ($5000+), and Leica M and SL ($6000+). And almost all CFast/XQD/CFexpress cameras come with an SD card slot as well. It's almost only the highest-end sports cameras (Nikon D5, Canon 1DX II) that come without SD card slots (Nikon's Z6/7 are the exception with only a single XQD card slot).
Reactions: nerdherdster
My new Nikon D4S still offers SC card support! And I still have a 2015 15" MacBook Pro because it still supports SD cards!
Well I hope you're not using UHS-II SD cards. Cause your MacBook Pro only supports basic SDXC card speeds. You would be much better off (and save a lot of time) by using an external UHS-II card reader.
So you're saying $2,000, $3,000 and even higher DSLR and Mirrorless cameras are being replaced by the iPhone? No, there is a lot of demand for sd cards and for my its a need. I have two cameras and both have SD cards.
I was very anti-dongle at first with my gal's 2014 MBP when I thought, "I need a Thunderbolt dongle for ethernet, really?!", but I got over it.
We've presently got an assortment of cameras using everything from older CF cards to MicroSD, SD UHS I & II, XQD, Thunderbolt 2, HDMI and soon CFexpress and I can only imagine what an absolute mess it would be to incorporate all of those different ports into a laptop just to try and appease every "my own particular needs" user.
But hey, "bravo to all you SD card users" if there's an SD slot, it's a non-productivity/creativity-affecting issue by my reckoning.
Now if this new MBP arrives with a Display HDR 1000 (or equivalent) screen and CPU/GPU hardware that makes Metal 2 FCPX/Motion/Compressor scream, well, "now we're talking!" :D
Reactions: Ploki
Tim Cook just announced it:
It's so strange to find myself in a situation where buying an Apple product seems like a huge risk and a potential poor decision. I sure hope this one won't suck.
Though to be honest, an imperceptibly larger screen, slightly higher resolution, better speakers and microphone don't sound like that much of a big upgrade unless you use the mic and speakers a lot. A "downgraded" keyboard is probably what it's all about, which to be fair isn't "new", it's just how keyboards used to be before the touchbar. So unless there's a new feature we don't know about, this is just the MacBook Pro that the first touchbar should have been several years ago.
Exactly this. So many people here who state they can't give their money fast enough to Apple, but if this 16" is just a spec bump with a new (old) keyboard and a marginally larger screen, what's the big deal? I guess we'll (hopefully) find out today.
The Canon EOS R isn't a professional camera (even Canon says so). The Panasonic S1R comes with both XQD (CFe) and SD, and for speed and reliabilities sake, everyone should be using the XQD interface, it's over twice as fast as UHS-II. Leica M isn't a professional camera, I know, I've had them all, from the M Monochrom, M9, M9-P, M240, M10 and M10-P. The next professional cameras from Nikon and Canon will all use CFExpress, now that the format "war" between XQD and CFast is over, and CFExpress (which is backwards compatible with XQD) won the war. XQD and CFExpress is also heavily used in most professional video cameras.
SD cards needs to die. The exposed pin's on SD cards is a serious reliability issue, and the main reason why SD cards often fail. XQD/CFExpress solves all of this, and is based on NVMe technology, with the speeds that comes with that (1st gen CFExpress cards are 1700MB/s read and 1200MB/s write and uses the PCIe 3.0 bus).
Reactions: mdatwood and DVD9
Was tongue in cheek, but curious why you feel so strongly that Apple couldn't.
They COULD but there have been absolutely no leaks that they would.
Realistically, we would have heard something already.
I'll go as far as admitting that IT COULD happen but I like your "tongue in cheek" response better.
I do audio, i'd prefer two 1/4" balanced jacks or XLRs on it.
Pointless really, SD cards get faster and via thunderbolt3 you can get a faster adapter. Or you change a camera and SD reader becomes pointless.
I used the SD-reader on my 2012 rMBP three times.
I used the SD-reader on my 40$ usb-c dongle two times.
I use thunderbolt and thunderbolt/firewire everyday. I also use balanced 1/4" jacks everyday.
The point of convertible highspeed extension ports is the same as the point of PCIe extensions slots - you get a solid powerful base and build around it.
The big deal is that I would've bought the current MacBook Pro ages ago if it weren't for the keyboard. (And, before the 2018 model, if it weren't for the 16 GB limitation.)
They have MiniLED at minimum next year; like many Apple products that get revised in a major way, it seemingly makes sense by the minute to wait till the next update unless you're on a 2015 rMBP on its last legs or something.
Especially if this laptop doesn't have Wifi6, LPDDR4 RAM, or PCIe4
Does it make sense for Apple to release Macs with MiniLED displays only next year, while still releasing a brand new 16-inch MacBook Pro this November? Odd.
Reactions: DVD9
If the chip and ram and hard drive and gpu are performing to spec, and delivering performance at or near top of class, what is your concern with the thermals? You suggested super thermal throttling. What is being throttled?
Theres a difference between a dash and a marathon! If you need the performance for rendering its just not there! The other aspect is the power draw can exceed the combined battery and power adapter! To speed up a long rendering process, pro's shove their system into ice boxes!
Following yesterday's report on Apple's new 16-inch MacBook Pro which could be announced as soon as Wednesday, Bloomberg journalist Mark Gurman this morning shared some additional details about the upcoming machine via Twitter.
According to Gurman, the display on the new MacBook Pro is less than four percent larger than the current 15.4-inch MacBook Pro, suggesting to him that "it's really going to be about the higher resolution" rather than a significant material increase in screen real estate.
Gurman offers no clues as to the exact resolution, but reliable IHS Markit analyst Jeff Lin claimed in June that the 16-inch MacBook Pro would feature an LCD panel with a resolution of 3,072×1,920 pixels supplied by LG Display. For comparison, the 15-inch ?MacBook Pro? has a resolution of 2,880×1,800 pixels.
In addition, Gurman says the new 16-inch MacBook Pro will have "impressive speakers" and "noise cancelling microphones," which sounds like a reference to an improved ambient noise reduction feature enabling users to capture less background noise when using the built-in microphones, thereby improving dictation and FaceTime calls.
Otherwise, Gurman reiterates Apple's focus on providing users with a more reliable keyboard that uses a new scissor switch mechanism, which is "similar to the iMac external Magic Keyboard."
The new 16-inch machine, which will be the largest laptop Apple has offered for sale since the 17-inch ?MacBook Pro? was discontinued, will replace the current 15-inch model and "cost about the same," Gurman revealed on Tuesday. The 15-inch ?MacBook Pro starts at $2,399.
Apple is said to have been holding private press briefings at its luxury loft mansion in New York City this week, likely providing media sites with review units for first impressions. Apple will surely announce the new 16-inch ?MacBook Pro? via press release, as there are no more Apple events expected this year.
Article Link: Gurman: 16-inch MacBook Pro Has Improved Speakers, Noise-Cancelling Microphones, and '4% Larger' Screen Than 15.4-inch Model
If there's no usb-A, my next machine will not be a Mac. Few days ago, I had to print something urgently (literally had 2 minutes to do it) so I rushed to the basement with my 2017 MBP 15". Someone put a flash drive in my hand to speed thing up... I just stood there defeated, because I didn't have the **** dongle with me. At this point I can be half as frustrated with a PC at half the cost.
Reactions: DanBig
Because they want to see how the public receives the new 16" Pro -- specifically the new keyboard. Plus, they probably have tons of inventory of the old Pros and want to sell them off with the holiday season (Costco = $999.) Release a new 13" Pro right now and you've suddenly got people asking themselves, "what do I buy?" Apple's not dumb; they're going to clear out old inventory first.
Well, Apple cannot get it wrong with the keyboard this time. They might play safe. It would be a shame to have to change the keyboard again after this.
Yes, the world's most expensive keyboard (with a complementary computer included). :)
[automerge]1573652432[/automerge]
Anybody care to guess how much a fully spec-ed out 16" MBP will cost (8-core/64GB/8TB/5000M GPU)?
If you have to ask...
