Me, yesterday, with my 8x10 view camera and Fuji Velvia film.Photographers can do perfectly fine work without a computer at all.
Regarding the mini it’s true they shifted the product, moving it upmarket, so again, you’re likely right and they were figuring out what to do with it.My guess is that it was the former—that every year they couldn't decide whether to keep it or not, so they just kept kicking the decision down the road without updating it.
The 2014 Mini used 2-core U-series chips. Here's the GB single-core and multi-core scores for the upper-end model, which used a Core i7:
Mac mini (Late 2014)
Intel Core i7-4578U @ 3.0 GHz (2 cores)767
Intel Core i7-4578U @ 3.0 GHz (2 cores)1628
If they had updated it in, say, mid-2017, with the then-available 2-core i7 U-series chips, here's about the performance we woud have seen (see data at bottom). So a bit under 20% improvement in single core, and a bit under 30% in multi-core. Nothing earth-shattering, but certainly an improvement. And it's not just about the CPU speeds. Without turning this into a research project, I imagine the 2017 chip would also have offered better graphics performance, monitor support, and I/O. Plus if they'd updated it in 2017, it would have had sigificantly faster storage, and perhaps also faster RAM.
Finally, being a later model, it would have had more years ahead of it before obsolesence as a result of not being able to run the current supported OS.
So there really is no technical justification for not updating it by mid-2017 at the latest (and probably earlier, like all the other Macs), rather than waiting until late 2018. I think that's why Schiller gave such a strained response when he was asked about it at that time (see my quote of Schiller in a post one page back).
MacBook Pro (13-inch Mid 2017)
Intel Core i7-7567U @ 3.5 GHz (2 cores)902
Intel Core i7-7567U @ 3.5 GHz (2 cores)2079
I believe the future will be the notebook vs desktop differentiation will not exist as we know it. Zero SoC differentiation.I think the benchmark results speek for themselves.
With intel we mainly differentiated the chips based on TDP. With more power per watt from the ARM chips we may need to adjust our view of what is laptop or desktop.
Lol it was a joke but I don’t put anything past Apple !iMac was already redesigned and without a NOTCH! What sort of logic makes you believe it would have a notch? Not that I care if it did, but larger display with thicker bezels means more space to place the front camera.
ever heard of dual screens?
That would result in 137.68 ppi. The current 27" iMac has 218 ppi. So your desired size/resolution would look like a pile of crap compared to that. Nobody want's that at least no Pros and definitely not Apple.32" @ 4k would be good enough.
Same thing I said lmao."Similar design to iMac 24 and Pro Display XDR". How is that possible?, they are both very different; the iMac 24 has a "chin" the Pro Display XDR doesn't.
Careful what you wish forIN BLACK PLEASE. WITH BLACK BEZELS.
Give me one in black and you can put a notch on every side and have the wallpaper locked to an HD close up of Bono.
Lol, plenty of Pro's use a 32" 4k display.That would result in 137.68 ppi. The current 27" iMac has 218 ppi. So your desired size/resolution would look like a pile of crap compared to that. Nobody want's that at least no Pros and definitely not Apple.
4K@2x is bad enough on my 24” Dell P2415Q, much less on a 32” display and I have no desire to display 4K@1x on a 32” display, most here don’t have that desire either. There is no “new” standard size display. I have a 24” and 27” 4K displays and 32” is just another panel size which is hilarious because the 4K gods can’t figure out the best size for 4K, hence all these display sizes. Apple is going to build displays with a resolution that makes @2x look good, not simply to fill out a spec sheet for PC builders, who will buy whatever the market craps out. When it comes to resolution versus monitor size there is very little consensus or “standard”. The top resolution of the 30” XDR is extremely high and 30” is the largest you’ll see in an iMac.Lol, plenty of Pro's use a 32" 4k display.
Yes, 5k or 6k would be better, but at a minimum it should be 4k. My bigger point was that the iMac should bump to 32", that's the where the market for displays is moving as a new standard.
Apple wouldn't do a 4k 32", because all their displays have a "Retina" pixel density which, for external monitors, means ~220 ppi. That's the minimum needed for text to be sharp with their new OS's (now that they've abandoned subpixel text rendering) To achieve that with a 32" requires 6k, which is why the XDR is 6k (this gives it 218 ppi).Lol, plenty of Pro's use a 32" 4k display.
Well, I guess I would get used to 32" but I was looking forward to 27". I've been using 21" iMacs since 2009, so frankly over 27" kind of scares me...27” is a ‘massive’ mistake Apple. I can’t imagine anyone wanting 27” over 32” as anyone with size constraints will surely get the 24”.
Maybe the return of 3 iMac sizes? ..Maybe?
Apple will most likey offer a standard "27 inch iMac" and a higher-end "iMac Pro," just like their Intel iMacs. Most of the iMac's target market just needs an AIO desktop with a reasonably sized screen, not a Mac Pro class workstation.My concern is the price, the previous iMac Pro started at $5000. I hope they don't take a similar path with this machine and force us to spend that much just to get an iMac with a 27" screen.
Note that 4k on a 34" screen means 130 ppi. I.e., when you say 4k on a 34", you are effectively also saying 130 ppi. Here's why:Woah I never said looking at 4K at 130ppi on a 34" screen I said I'd rather look at 4K on a 34" screen, but not that that terrible pixel density. Current pricing doesn't match quality so I never purchased a 4K screen at all. I don't need 4K currently maybe in a year possibly but not needed for me right now and surely not that that terrible pixel density - my eyes suffer enough lol.
Amen! Apple should stop making expensive all-in-ones and go back to separate displays and computers, except now much smaller and lighter and with battery power. Then we don’t have to compromise or waste money, we can get whatever size screens we want (and they would work with any source) and however powerful a computer we want.For the last time: I DO NOT WANT TO HAVE TO CHOOSE BETWEEN SCREEN SIZE AND FEATURE SET!
Why should I have to fork over a bunch of money for Pro features when all I want is a larger screen for doom scrolling???
Stop making the iMac? You must be joking. The iMac is the most iconic computer that Apple ever produced. The All-in-One nature of the computer is what makes it so great. If you don't like that, then there is always the PC world.Amen! Apple should stop making expensive all-in-ones and go back to separate displays and computers, except now much smaller and lighter and with battery power. Then we don’t have to compromise or waste money, we can get whatever size screens we want (and they would work with any source) and however powerful a computer we want.
One USB-C cable between them would be so neat and clean. Nothing else plugged in to the back of the display, no ugly vga cables with screws and thick power cables gathering dust bunnies.
The chin is going nowhere. People need to accept this reality.If they can contain an XDR display within the MBP lid, I think it should be possible to contain the guts behind the display of an iMac. It would have to be thicker, of course.
FaceID on a Mac would be great. This technology is one of the coolest features on the iPhones/iPad Pros.
Buy a Mac mini and a 5K external display. This is what Apple does, have you not been paying attention for the last 12 years?For the last time: I DO NOT WANT TO HAVE TO CHOOSE BETWEEN SCREEN SIZE AND FEATURE SET!
