HobeSoundDarryl
macrumors G5
this is a valid point, some of these iMac’s need to be more powerful then the current MBPs. i’m talking top of the line fully maxed models. I guess the iMacs won’t be power limited the way the laptops are, but it needs to be more than that and a fancy screen doesn’t cut it especially if they bring back the iMac Pro… that model needs to be a beast that will put a MBP M1 Max to shame….
I like the sentiment but would have very little hope/expectation of this less than or equal to 6 months from now. You may be imagining M2 MAX or M3 MAX.
Conceptually, an assumption of an always-powered/no battery management Mac could run in this MAX "high power" mode more of the time when that is needed.
Best hope for this would be that with the expected M2, there is also a rollout of M2 PRO and M2 MAX at the same time. Personally, I would strongly doubt that 6 months from now but anything is possible. My guess is that M2 PRO & MAX are "next Fall" and wonder if another tier of bigger iMac waits for that point in time too.
The interesting thing about the transition is that what is traditionally considered the most powerful Macs are still to come. MBpro just got an incredible set of chips. iMac and then Mac Pro seems like they should roll out with even more power. But the timing seems messy if iMac is launching only 6 or so months from now.
If they do- for example, if there is M2 and M2 PRO & M2 MAX in 6 months (something I personally doubt)- it would imply a "big advancement" pattern every 6 months. With no expectations of Mac Pro in 6 months but either WWDC or next Fall, it seems it MUST be another leap. if M2 PRO & MAX are already 3-6 months old when it is revealed, is that M3? And if so, it even more strongly implies major leaps every 6 months.
If Apple could do that, great! But wow, I'm not seeing it. Instead I would guess for bigger iMac (and hopefully Mac Mini Pro) with the same PRO & MAX options in the Spring and then M2 PRO & MAX next Fall (Mac Pro, maybe Mac Pro Jr, maybe the bigger iMac that is expected but doesn't roll out in the Spring). All just wild guesses.
