You knew a new one would come outBut I just bought the new 16" MBP...!
Late 2020. Whatever made you think that after you bought your mbp that Apple would suddenly stop doing a yearly release?
Simple: USB-C support and new processor allowing transparency by touching one side; similar to AirPod Pro or the Sony XM-3.I am really looking forward to the 2020 iPhones as it is sounding like there will be numerous, significant improvements. Is there anything in particular your wife is expecting in Studio 4 headphones? I love my Studio 3 headphones and I really can't think of anything they are lacking. I'm not an audiophile so the current quality of sound is good enough for me (for my use case, I doubt I would even notice if the sound quality was improved). The ANC works well and the battery life is great. Just wondering what she is expecting in the next version.
Kuo has also previously said that future iPad and MacBook displays will each use approximately 10,000 LEDs, compared to 576 in Apple's upcoming Pro Display XDR. Each LED would be below 200 microns in size.
So the current MBP 16 is almost 4k (3072‑by‑1920), and given my retina MacBook Pro 15 at 1920-by1200 is too small for me to see , are you advocating that even teeny-tinier is better? Would it even be noticeable? Is the law of diminishing returns in effect here?Would Mini-LED up the resolution of the 16" or just update the brightness and contrast?
Yah, where is technology perfected? it seems every single bit of technology has some limitations, what is wrong with engineers anyway?Can't wait for all the posts about how mini LED is going to solve all the LCD and OLED problems only to find in a year that mini LED has a bunch of problems of its own
Kuo said we were getting new iPad pros, in October, kuo is wrong way more than he is correct, pretty sure financial analysts don’t listen to him anymore since he is always way off with projected sales, most of the time he isn’t even close.I was hoping for iPad Pro update to be within the first half of 2020. 🙁
Mini-LEDs are just the back light, the screen is still LCD, presumably at the same resolution.Would Mini-LED up the resolution of the 16" or just update the brightness and contrast?
I mean, we've just had the 16" MacBook Pro that he promised as early as February, and he was even right on timeframe, which is where he can be a little hit and miss.Kuo said we were getting new iPad pros, in October, kuo is wrong way more than he is correct, pretty sure financial analysts don’t listen to him anymore since he is always way off with projected sales, most of the time he isn’t even close.
People call him a Well respected Apple analysts, since he lost his contact he hasn’t gotten anything correct.
So, could this be the reason why Apple hasn't implemented HDR into their laptop displays? Is it because Mini/MicroLED will significantly reduce the cost to implement HDR compared to OLED?
Kuo is usually pretty on point but this seems unlikely, especially for the 16" Pro. I personally feel Apple will update the 16" in Q3 with 10th gen CPUs and WiFi 6.
The mini-LED tech just seems too far off but who knows, Apple can be unpredictable sometime
3072x1920 is not close to 4K, which with the MBP's aspect ratio would be 3840x2400. That is only 64% the pixel count of 4K, or 71% if we're comparing it to the PC laptops that use the 16:9 aspect ratio (3840x2160).So the current MBP 16 is almost 4k (3072‑by‑1920), and given my retina MacBook Pro 15 at 1920-by1200 is too small for me to see , are you advocating that even teeny-tinier is better? Would it even be noticeable? Is the law of diminishing returns in effect here?
Not criticizing, just trying to understand if this is deemed as a benefit
If it's an expensive technology, it makes sense to start it on the most expensive devices first, but also to use it on as many devices as economically possible as quickly as possible to benefit from economy of scale and quickly amortise R&D costs. Having said that, this isn't micro-LED, but mini-LED (basically a fancy backlight to help a regular LCD panel achieve HDR black levels by dynamically dimming behind black areas) so I don't think it's likely to be astronomically expensive, unlike actual micro-LED.The cost of micro led technology is still expensive so to put it in a 16in screen is going to cost more than a LCD screen ATM. I think Apple will use them but they will start with iPads and lower end macbook's to test out the technology and keep the cost lower on the laptops.
