Have you tried to reset the Bluetooth Controller on your iPhone?I'm using an iPhone 7 and have had 3 pairs with the drain issue.
http://www.imore.com/how-to-fix-bluetooth-iphone-ipadNo I haven't actually. How would one do so??!
Don't peek, because that is causing the drain, haha
My daughter has an iPhone 5, I have a 7plus... she hasn't had the same problems.Same here, the courier came Friday 6th, and they are on their way to Cork, Ireland.
[doublepost=1483800315][/doublepost]Try this (it really kind of works): Don't check the battery. Sound dumb, I know, but always when I use the Battery of the AirPods enough, that by putting them back to the case the amber light goes on and then don't open the lid until I really want to use them again for at least 40 min, the case's Battery hols a lot longer as no Lightning is seen next to the AirPods when opening the Lid. But, just opening the Lid and checking the Battery status forces the AirPods to stay awake and the drain begins.
[doublepost=1483800620][/doublepost]Maybe let's start a little poll: What iPhone do you use? In most reviews the are using an iPhone 7 and have no complains. I use an iPhone 6 and so does my girlfriend and we both have that drain-issue with the same pair of AirPods. So let's hear, what you have got.
Does it discharge though when you're not using it?Charged my case up last night. Only need to do it 4-5 days.
Straight out of the box or after a few charge cycles? Mine drops about 1% an hour which is still almost 5 full days.It only uses up battery when I put them back in after usage. If the air pods stay in the case it barely drains at it. Think it drained 10% over like a day and half when I didn't use them at all.
pretty much straight out the box. Battery life has been great throughout.Straight out of the box or after a few charge cycles? Mine drops about 1% an hour which is still almost 5 full days.
yes - I find the pods are about that.. give or take and depends on if you use it for calls.pretty much straight out the box. Battery life has been great throughout.
The 5 hours Apple claim with usage on air pods seem about right.
replacement AirPods arrive today... stand by for incoming once i get a chance to test them 🙂Same here, the courier came Friday 6th, and they are on their way to Cork, Ireland.
Still waiting for mine. So what are you experiencing with your new pair?replacement AirPods arrive today... stand by for incoming once i get a chance to test them 🙂
these seem fine!! still need to do a couple of charge cycles to finally be able to put this behind me... but definitely not whizzing through the case battery...Still waiting for mine. So what are you experiencing with your new pair?
Nice! This is great news. I'm still missing mine. Apple received them last Monday in Ireland but since then I haven't heard anything. How long did it take in your case?these seem fine!! still need to do a couple of charge cycles to finally be able to put this behind me... but definitely not whizzing through the case battery...
