SactoGuy18
macrumors 603
That's why my iPhone 12 is running on right now. I'll wait for iOS 16.1 with more significant fixes in mid-October 2022.Gonna stay on iOS 15.7 for now ...
Sad but so true.@sorgo
No no no no. This amount of steps for disabling a toggle that clearly is not working as intended... come on. This is crazy. This is insane. How is this even possible?. How it´s happening?. What kind of QA is this?. How this survived even the early stages of the IOS 16 betas, and is present in the final released version?. Do Apple even use their own software?
That first photo is for 10 day use. So Facebook was around 3 hours total use for 10 days. Or 12 percent last 24 hours (second photo)rjjacobson, if the Facebook app is hogging THAT much battery power, I might as just access Facebook using Safari and/or Chrome instead.
Are you using the cable that came in the box along with an Apple plug they sell seperately? I am and not had that.I had my first issue yesterday with my 14 Pro Max 256 GB. The phone just randomly shut off while it was at 87% battery. Had to force restart it to get it back up and running. My Dad's 14 Pro Max has had this issue twice already.
(Work in QA myself and agree that these bugs are rampant within iOS 16.0, a mix of low and high-priority issues for this release)
It’s harder to track down on iOS than on Mac OS as you don’t get as much detail.I am not having this problem but I have seen it mentioned how do you find a runaway process will it show in battery usage info or is it unseen in background. I always kill my apps periodically on screen so they are not running in background in anyway. And when iOS gets weird with errors then time for a reboot of phone. I seem to avoid most problems at least in my experience.
Thanks sorta what I was thinking but you confirmed for meIt’s harder to track down on iOS than on Mac OS as you don’t get as much detail.
As you have seen, the battery usage screen will show you which apps are using power. What that won’t tell you is if some system process is running hot. Sometimes a reboot can help if it is a transient situation.
How long did you and your dad have new phones before these issues appeared (just curious if this is just after the install and while the phone is busy for a day or few days later). I have not seen this at all on my 14 ProMax 1 TB.
I always have problems setting up polls here but wonder about a number of issues.
1) Battery drain is it worse on the smaller 14 Pro battery, from some discussions it makes me wonder…. Other issues have not seen or experienced since I got mine on 16th of September.
2) Even CarPlay is fine in 16.01 and 16.02 for me on my Mazda 6, but mine is a wired aftermarket add by dealer (my car is 2016 so CarPlay took a couple years to be available). So is issue with wired CarPlay or bluetooth CarPlay? Lots of questions
Even with iOS 16.1 I will first read some feedback from the people here. Usually Apple screws up the first couple of updates before it stabilises.That's why my iPhone 12 is running on right now. I'll wait for iOS 16.1 with more significant fixes in mid-October 2022.
This is why I think iOS 17 will be more like MacOS X 10.6 Snow Leopard, where the emphasis will be more on bug fixes than new features.Even with iOS 16.1 I will first read some feedback from the people here. Usually Apple screws up the first couple of updates before it stabilises.
Ensure all your system services settings are set on.I'm using the 14 pro on 16.0.2, the auto appearance still does not automatically toggle between light and dark mode. I've tried setting it to sunrise/sunset AND a custom time, neither works. Also tried resetting the phone, no help. Is this a known bug? Is it iOS 16 or the 14 pro? Thanks for any perspective offered!
Thanks but they are all on, still doesn't help.Ensure all your system services settings are set on.
