You seem to be horribly misinformed. The 5S with its dual core A7 is noticeably faster than the Galaxy S5 in almost every task imaginable (and the benchmarks back this up). I would suggest reading something/anything about the way modern CPU's work before commenting further on this. For a quick example, see how the Intel quad-cores stomp the octo-core AMD's:
http://www.anandtech.com/show/8426/...view-core-i7-5960x-i7-5930k-i7-5820k-tested/5
Additionally, most photographers (actual photographers, not some guy who knows how to take a selfie) agree that the 5S has the best camera outside of maybe the better Lumia's. The 5S objectively has a much better sensor and signal processing than the S5's camera, and performs much better in low-light (with or without flash).
Regarding RAM, I won't defend Apple's decision to go with 1GB if that is, in fact, true, but it's probably still vastly better than the S5 running TouchWiz because of how much of a RAM-hog TouchWiz is. Here's a fun screenshot from an S5 user on Android Central who was ONLY using his phone to stream HBO Go to a Chromecast:
I hope Apple does include 2GB, but the reality is that 1GB running iOS is probably quite a bit better than TouchWizified Android on 2GB.
Regarding battery, the S5's improved battery life over its predecessor is almost entirely due to the lower power consumption of the Snapdragon 801. Note the difference between the S5 and S4 in Anandtech's LTE test:
It's going to be hard to say how this will turn out when the iPhone is running a 20nm A8 on iOS 8 -- I would not be surprised at all if an 1800 mah battery is enough to beat the S5 on battery life.
One point I'll completely agree with is that another 326 ppi display in the 4.7" model would be quite disappointing. If they can hit the 1704x960 resolution, though, it'll have just north of 400 ppi and that would probably not be noticeably different than the 1080p 5" Androids. This is probably unlikely, though, for the reasons Gruber put forth.
If the rumors about the 5.5" version are true, however -- with its @3x resolution, 2900 mah battery, and OIS, it'll probably crush the new Galaxy Note in every respect.
