Wrong actually"You'll notice that yes, I did mention Siri: Your AirPods are hooked directly into your iPhone's personal voice-based assistant, and can be triggered with a double tap of either one of your AirPods, Her-style. Siri is the primary way you interface with the AirPods — there aren't any minuscule play/pause, volume, or track controls on these earbuds. Instead, you ask Siri to pause your music, raise the volume, or switch to the next track."
http://www.imore.com/airpods
Try to do more research next time, my friend.
You can change the settings from double tap for Siri to use play /pause
You can't with volume but with play and pause you can.
