thejadedmonkey
macrumors G3
I don't understand how they can remove 2 ports, not add the standard SD port on all of their other consumer machines, and still charge $999 for it.
Wait's for new CrackBook stories to emerge in next few months.
Seriously, from a guy who used to own a Black MacBook 2.4, stay away, they overheat and then crack.
Fork out the extra dosh for a MacBook Pro Alu.
It will be back in the next revision. 🙄
Why doesn't just use the same logic board as the 13" MacBook Pro? It'd be cheaper for Apple.
This time I think you're out of luck. Apple is going to say that removing FW is one of the things that enabled them to hit the sub-$1000 price point, and that anyone who needs it should move to the 13" pro model (which wasn't an option before).
Apple misjudged the size of the negative reaction the first time but probably not this time.
Of course, but FireWire is a must-have for each and every Mac. The previous model had it (FireWire 400).
No its plastic, but made from a single mold instead of numerous parts and seems
So it's a unibody, but a plastic unibody? Is it polycarbonate?
Many people live just fine without FW. My wife has the original MB unibody from a year ago. Hasn't had a need for FW once. I have it in my two year old 15 MBP, but I have only used it once in that time. FW is simply not a "must have" feature for many users.
The Pound has lost value against the Dollar and the Euro since a year ago. Don't rage against Apple, rage against international currency markets and the global banking collapse.
Will Leopard 10.5 work on these new Macbooks? We're in an enterprise setting, and do not support 10.6 at this point, as the software used here will not work on 10.6. At this point, we been wiping the drives on the new Macs and installing Leopard 10.5 on them.
All signs point to yes unless they changed the trackpad drastically enough.Anyone want to venture a guess on this?
My wife was just about due for a new MacBook, but no chance I'll buy her this one...I have 2 external firewire drives and a non-HD firewire camcorder. Dumb move Apple, dumb.
I take a MacBook with a user replaceable battery anyday. Call me old school but other than that, very nice.
Is this the same crappy plastic that featured on previous macbooks?
My macbook is cracked and battered to hell and I wouldn't consider buying a laptop with the same build quality ever again.
