Extremely busy day at work. iPhone 12 Pro Max - Pure Beast!!!
Just checked. -96. Not the best but not terrible. But frankly, while that will have an impact, as a customer I shouldn't care/worry about it. This is my 7th iPhone, the 3rd in this very house. None had this issue. My wife's OnePlus 8 is literally almost next to my iPhone, no drain. I also tried a friend's Samsung S20 FE. It's on 20% right now, 5 hours on screen time and 3 nights in the same room as my iPhone 12 overnight.
Can't say as I'm using it, but it does feel less tbh. I'm losing 25% overnight, so it should be dead the night after but it's not.
Not using a single widget.
A poll I did on Reddit 3 days ago.
iPhone 12 mini thread, Wi-Fi on, airplane mode off.
Thanks for sharing. Sounds like my battery drain is definitely worse than average, although I don't have the mini.
Btw, the aforementioned Samsung S20 FE is now at 17% with 10 hours on screen time over the course of 5 days. And that's with always-on-display on. A phone that costs £350 less than my iPhone 12. 🙁
(not to mention that the S20 FE runs at 120Hz refresh rate...)
Really annoyed at this point tbh. Especially given that reports about battery drain are all over the internet but nothing has happened for well over a month now from Apple's side.
Reactions: The Cockney Rebel
I’ve performed another complete factory reset, and set everything up as new (did it yesterday).
I left it alone all night, to index & what not.
I just installed my apps manually, and have put the iPhone on charge.
I’ll disconnect it, when it reaches 100%.
I’ll let you know if the drain persists.
The battery life on my iPhone 11 was superb.
Yep. I still have my iPhone 11 (sending it for trade-in today though). It's running on the same iOS version but has almost no drain at all overnight. So it's either iPhone 12 hardware or the combination of 12 hardware and iOS 14.
I also sent my 11 in for trade-in.
I’m hoping this is a software/firmware issue.
Keep me updated re your own phone, and I’ll do the same. Sometimes it’s the most unbelievable glitch that can cause issues. For example, I found out that I couldn’t set reminders by time if my clock was set to 12 hours (as opposed to 24.) This was driving a lot of people mad, but I figured it out.
Let’s get this sorted between us.
I just did the same last night and my drain was about 2-3% over night.T-Mobile USA and 12 pro max. I installed maybe 10 apps but left all the settings untouched just to see.
That sounds promising.
Now change the settings to how you like them & see if that makes a difference.
For me 14.3 fixed the night battery drain issues I have been having on my iPhone 12 Pro Max.
Same for me. It didn't even drop 1% during the night since i took 7.3. Now daytime it does feel like it drains more than earlier...
Oh well, at least i get something done using battery vs drainage during night. 🙂
Since I always recharge just before going to bed I doubt I would ever experience this drain even if it were a problem. I’ve never had a problem with battery life by leaving my phone on the charger all night.
Contacted Apple support yesterday, just to be sure. They ran the usual diagnostics and found that the phone is in prime condition. Then they proceeded to instruct me to force-update to iOS 14.3 again, even though I was already running 14.3
Well - last night I had 30% battery drain in 8 hours. So that didn't fix it... The only thing Apple support suggested now was to read the generic battery knowledge pages - obviously rather unhelpful. However, I asked them to escalate it to the engineering team directly, but given how widespread this is, I reckon they already know (hopefully).
Any news from those who factory reset their phones?
Yes, i ve done it. Twice. On my 12 pro. Don't bother. Pretty inconsistent battery life and idle drain still.
  • Angry
Reactions: behrendtio
So as you probably know, I factory reset my phone.
Left it to index for a night, then installed a relatively small amount of apps.
Since my last 100% full charge, I’ve lost 30% in a 12 hour period.
I’d say that’s quite acceptable?
My advice is to do what I did. I find that my iPhone 11 had better battery life, but I’ve since switch from Three to o2, so they could play a part in it.
I’m at my Nan’s for the weekend, so will be solely on cellular. I’ll update as the weekend progresses.
I think that’s great! I did the same the other day. I reinstalled 14.3 from my MacBook then I didn’t transfer any data from iCloud backup, necessary info is already synced automatically when I login to Apple ID. This time I chose not to restore from iCloud backup. I made sure each app had its own sync within the app or backup to Dropbox etc. I wanted to make it as brand new as possible. The battery has been great since then, so far lost 6% in the past 5 hours with moderate use(no streamin yet) but screen was on for most of the time. Also the yellowish tint somehow got much better and more bluish with True Tone on and screen looks much crispier. Also it runs more snappy.
T
You have to register there and then update the software.
Thanks, buddy.
Downloading the beta right now. It’s going to take a while, as I’m piggybacking on my sister’s WiFi, from two houses along!
The fella who mentioned before how the new update has fixed the battery drain has given me hope.
Reactions: ExploRichie
